20 Most Recent Uniden Bearcat BC75XLT Police Scanner Questions & Answers
Bc75xlt scannerfrequencies
Hi, Michael,Your best bet is the ACMA website, depending on where you live, i.e: state/postcode, you need this info plus frequency range that you're interested in before looking up their register of communications licenses.A cheap way of getting a basic knowledge of Australia wide frequencies is to go to ebay and bid for a copy of Scanner Fanatics frequency register, these are the same books that sold in DSE years ago. They are up-to-date as far as I know, but they are a good way to get started in scanning.RegardsPeter
12/14/2017 12:49:46 AM • Uniden Bearcat... • Answered on Dec 14, 2017
2answers
Transmission breaking up
Without having the scanner to examine, my first thought is that you have the squelch set too high, and the signal is not very strong. Try putting and external antenna on the radio and see if you don't get better copy. Lastly, there could be a problem with the radio as well, but like I said, without examining the radio I can't know that.
4/9/2017 7:51:38 AM • Uniden Bearcat... • Answered on Apr 09, 2017
How do I erase the codes in my bc75xlt police scanner and reenter new frequency codes
Go to the UNIDEN Website and download the programming software. It is much easier than by hand. http://info.uniden.com/twiki/bin/view/UnidenMan4/BC75XLT
1/23/2016 7:09:45 AM • Uniden Bearcat... • Answered on Jan 23, 2016
Why is there no squelch at all?
no noise or you have noise constantly?
1/9/2016 11:57:35 PM • Uniden Bearcat... • Answered on Jan 09, 2016
Radio works fine but the display is totally blank.
Radio with display often have a wire that powers the display. This is separate from what powers the unit, memory funcion, and from switched power that signals the device to power on. Each of those wires should receive power or signal from separate sources, respectively.
Inspect All connections. This includes wiring and contacts/terminals. If terminals are corroded, a small Allen wrench can be used to "de-pin" the plug for repair. The locking tab on each de-pinned terminal must be bent back to its original position, or it will fail to engage the plug, when pressed back into position.
It could be a faulty unit, though I encourage you to read the installation manual, if available, and eliminate the obvious while taking notes for future reference during the troubleshooting process. Good luxk
11/4/2015 3:28:26 PM • Uniden Bearcat... • Answered on Nov 04, 2015
How to reset my Uniden BC75XLT Bearcat Scanner .
Resetting the Scanner If the scanner's display locks up or stops operating properly, you might need to reset the scanner. CAUTION: This procedure clears all the information you have stored in the scanner. Before you reset the scanner, try turning it off and back on to see if it begins working properly. Reset the scanner only when you are sure it is not working properly. 1. Turn off the scanner. 2. While holding down 2, 9, and Hold, turn on the scanner. It takes about 3 seconds to initialize and CLEAr appears.
10/26/2014 12:13:29 AM • Uniden Bearcat... • Answered on Oct 26, 2014
Scanner mods
right here
2/17/2014 8:44:44 AM • Uniden Bearcat... • Answered on Feb 17, 2014
3answers
Need free codes for a base police scanner
hello there
please try these links they have worked for me
  1. Scanner Frequencies & Codes Free Trunked Fleet ID's for your area (Works with Scancat) Military Base Operations Frequencies ... Get a scanner frequency list by email for your county, ...www.bearcat1.com/free.htm - Cached
  2. Portland Police Scanner | Portland, Oregon Crime & Emergency Dispatcher ... ... use of a Trunk Tracking Scanner and entering the Talkgroup codes listed in the next section. ... your Business Listing for free. Obits / Death Notices ...oregonlive.com/policescanner/...?/policescanner/police_codes.frame - 64k - Cached
  3. Scanner Feeds ... Feeds Police Codes Police 11 Codes General Codes General Acronyms ... They are free. ... Big Bear, California Police Scanner (web-based) Los Angeles Police ...members.shaw.ca/crazykid755/scanner - Cached
2/7/2024 2:07:07 PM • Uniden Radio... • Answered on Feb 07, 2024
Owners manual Uniden Bearcat BC590XLT
The Owner Manual is here Noel
Bearcat BC-890XLT Scanner owner's Manual
repeater-builder.com https://www.repeater-builder.com > uniden > pdf PDF Please read this Operating Guide thoroughly before operating the scanner. Optional Accessories. The following optional accessories for your BC 890XLT are ... 40 pages ..
6/24/2023 5:09:47 PM • Uniden Radio... • Answered on Jun 24, 2023
Uniden Bearcat BC 220XLT Radio Scanner repair/service manual
Some help here, but what you want to be likely not possible. https://www.google.com/search?q=Uniden+Bearcat+BC+220XLT+service+manual ..
5/23/2023 2:41:51 AM • Uniden Radio... • Answered on May 23, 2023
I need a battery for UBC3000 please?
All questions need full 'make model (what it is)' or we guess. I see a number of UBC3000.
Uniden - UBC3000XLT Battery
Complete Battery Source https://www.completebatterysource.com > uniden-ubc... The Uniden - UBC3000XLT Nickel Metal Hydride (NIMH) battery is the perfect replacement battery at a great price! The Uniden - UBC3000XLT battery is ... Capacity: 1100 Length inches: 2.7 US$43.55
3/10/2023 11:22:58 PM • Uniden Radio... • Answered on Mar 10, 2023
D104-M6B WIRING FOR A UNIDEN 880 RADIO DIGRAM
Here is the wiring diagram for connecting a D104-M6B microphone to a Uniden 880 radio:
  • Shield: Connect to pin 1 of the microphone jack on the radio
  • White: Connect to pin 2 of the microphone jack on the radio
  • Red: Connect to pin 3 of the microphone jack on the radio
  • Black: Connect to pin 4 of the microphone jack on the radio
It's important to note that not all Uniden 880 radios are wired the same way. If you're unsure about the wiring on your specific radio, it's best to consult the manual or contact Uniden customer support for assistance.
2/26/2023 4:12:25 AM • Uniden Radio... • Answered on Feb 26, 2023
Uniden UBC370XLT Scanner. Hello, I am looking for a schematic diagram for a UBC370XLT. Does anyone have a copy or know where I might be able to get one please?
Question edited for clarity and add maker + (what it is). Question moved from Misc. You will have to contact Uniden direct. This search query should find it. The CLT model seems better known https://www.google.com/search?q=UBC370XLT+schematic More here including software https://www.google.com/search?q=%22UBC370XLT%22 ..
1/5/2023 2:36:14 AM • Uniden Radio... • Answered on Jan 05, 2023
Uniden 210 XLT. What modification to pick cell phone frequencies
Question edited into english. No modifications. The range is restricted and the calls are encrypted.
12/1/2022 4:28:40 AM • Uniden Radio... • Answered on Dec 01, 2022
How to wire a Superstar 507-5 microphone to a Uniden Washington base unit please?
It should just connect with the plug eBay states. This is a brand new Workman replacement omni-directional CB radio microphone. Features a 5-pin connector and a flexible coiled cord. Wiring:
  • Pin 1 - Audio
  • Pin 2 - Ground
  • Pin 3 - RX
  • Pin 4 - Common
  • Pin 5 - TX
  • Compatible Radios:
  • Cobra 90LTD
  • Cobra 140GTL
  • Cobra 142GTL
  • Cobra 148GTL
  • Cobra 148-F-GTL
  • Cobra 2000GTL
  • Cobra 2010
  • Uniden Washington
  • Uniden Grant XL
  • Uniden Madison
  • https://www.google.com/search?q=connect+Superstar+507-5+microphone+to+a+Uniden+Washington ..
    11/27/2022 9:08:36 PM • Uniden Radio... • Answered on Nov 27, 2022
    I have an Old Uniden BC760XLT scanner been sitting for months..now it Appears by the display To be Scanning,No Audio I've tried the internal/external speaker/recorder jack ..No Audio..any ideas?
    Probably has some leaky capacitors that stop it from working and just shows a display without tuning at all.
    7/6/2022 5:49:23 AM • Uniden Radio... • Answered on Jul 06, 2022
    I just received a Uniden Bearcat handheld scanner model BCD325P2.
    all it can do is in the manual. 2015 made new. all those safety channels frequencies are regulator by FCC.gov and are published here they are, first google hit ,amazing. https://www.radioreference.com/db/browse/stid/12 keep in mind some 800MHz transmitters (gov) are encrypted trunking mode radios, (like police is) in my town text, the HAM band 2meters has full time weather brocast (I have HT and HF here) our RAD does 25mHZ to 900mHz bands all stated in the manual below. page 129 covers the public service bands starting at 758.0125 MH vhf and uhv is line if site comms so that is why there are so many stations. (broad casting) best is try the closet one first. a better antenna , is what to use. what kinds of safety data do you need, not told fire, police , amber alerts, weather, road reports, and lots more what you want not told. but you can find it if you google that, in clear simple text. for sure. by county is best. as it is line of site. police bands are trunked and have are networked sites to overcome line of site issues,. (magic) and is encrypted.(and ******* to hack btw) broadcast is site by site and 20 miles max (aprox) but station power in watts is prime there, and no 2 stations are the same, (rare) set the radio to scan them all , see what it finds.? be patient. or look up what you want googled. https://www.manualslib.com/manual/952528/Uniden-Bcd325p2.html?page=129#manual good luck and happy DX'ing.
    7/2/2022 3:06:23 PM • Uniden Radio... • Answered on Jul 02, 2022
    How to setup a uniden BC75XLT BEARCAT?
    https://www.roadtrucker.com/images/manuals/uniden-bc75xlt-user-manual.pdf
    6/12/2022 11:17:03 PM • Uniden Radio... • Answered on Jun 12, 2022
    Uniden Bearcat BC75XLT Police Scanner Logo
    9 questions posted
    Top Uniden Radio Communications Experts
    John
    John
    eradiostore
    eradiostore
    Grand Canyon Tech
    Grand Canyon Tech
    Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
    View Most Popular
    • Uniden Radio Communications
    Most Popular Question
    transmission breaking up
    • Radio Communications
