20 Most Recent
Maycom AR-108 Air Band Scanner Questions & Answers
Radio case perished and sticky
Depends on what the product is. Alcohol works on a lot of products . So does plain water if it cuts the sticky substance.
Maycom ar-108 no sound
maycom 108 no sound on air band,i to had this problem,hold radio in hand and hit on to table with a fair hard force on bottom until sound returns,yes this will work,dont be afraid to do hard,
Buzzing noise in realistic pro 62 airband scanner
Check your squelch settings. The frequency you are trying to listen might be a "birdie", a frequency that interacts with the electronic noise in the unit. This is especially the case if the issue is only on one frequency.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
