20 Most Recent
Bosch 11241EVS SDS-Max Rotary Hammer Questions & Answers
What gear lube to use
1 bottle of 50ml oil BOSCH 1 615 437 511
But also a special kit thats neccesary if it had its working hours and was leaking in the front .
Not only a seal and o-rings to change is not enough
1 special kit BOSCH 1 617 000 430 if all parts are replaced don,t forget also to change the O-ring 1 617 000 430 on the right place see first how its fitted its included in the kit with seals but remarkable the oil is not allways in the kit
I have a bosch rotary hammer 11245evs and it was
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
I NEED TO KNOW THE
Carbon Brush Set number 1617014135, They cost around $14.00 for the set.
How much oil and what type goes back in the bosch
The best way is to find a Bosch service center and get the oil change kit. P/N 1615437511 this comes with a small bottle of oil and a top cover gasket. All you do is remove the top cover dump out the old oil and pour in the whole bottle of the new stuff. Couldn't be more simple.
