20 Most Recent Evesham Axis PC Desktop Questions & Answers
It should work provided the components do not draw more than 400W.
If the wattage is exceeded these switch mode power supplies usually automatically shut down.
I recommend you install a switch mode power supply over the 420W rating.
Evesham Axis PC... | Answered on Aug 15, 2012
it's an unusual brand, never heared about it, i've been searchin for long time but no resoults.
i think you can only contact them directly,
try this out:
Sandra Cheng
sandra.cheng@tatung.com
Tel :+886-2-2598-4540
Fax :+886-2-2592-4569
probably not the correct department but you are gonna be redirect to the right place.
hope this help,
regards,
Paolo.
Evesham Axis PC... | Answered on Feb 16, 2011
It might be best to upgrade your computer to something newer. You can even find something used on www.craigslist,org or www.ebay.com. I wouldnt put any money into a 10 year old computer. If you really want to upgrade to USB 2.0 - you'll most likely have software issues to overcome, too. Without knowing the full situation, it wouldnt be right to advise you to put money toward upgrading anything on your computer. Good luck.
Evesham Axis PC... | Answered on Dec 09, 2010
Go to the manufacturers web site. There you will have access to all maner of useful items including drivers, that are the latest and will work!
Hope this works.
Evesham Axis PC... | Answered on Nov 22, 2010
You can upgrage to as much as 3 gigs on that system and here is a link on how that is done
Evesham Axis PC... | Answered on Aug 21, 2010
Hi, try the realteck AC'97 sound driver, its free on a google search, or try this link: http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Hope this helps
Evesham Axis PC... | Answered on Jul 27, 2010
Yes, it sounds like you need to update the driver for your Audio Card. You can do this automatically using a program called DriverEasy from the following site: http://www.drivereasy.com/
Follow the instructions on the web page and choose to install the driver for your sound card which should appear in the list.
Evesham Axis PC... | Answered on Jul 08, 2010
hi, i suggest you check the hardwares like the RAM if u have 2 slots remove one try the other if it continues try the second on various slots. u can check the harddisk to for it to be fixed firmly
Evesham Axis PC... | Answered on Jun 08, 2010
"legacy" means =old version, so the "latest legacy" wont work--try the latest driver from the graphic card manufacturers website
Evesham Axis PC... | Answered on Apr 13, 2010
if u have made sure both ends of the power cord are attached and plug in properly and that the outlet has juice if so it is either your power supply or power button with an issue or short if both those are checked out and fine than it may be a software or motherboard issue in which case you would need to contact the manufacturer
Evesham Axis PC... | Answered on Mar 30, 2010
Would need more details about your motherboard, and if there is no BIOS showing or anything. Not sure about what you are meaning by beeps but it may not be a factor anyway.
I think the first thing to try would be to remove CPU fan, CPU Heatsink, inspect and replace thermal grease if necessary.
Remove old residue with paper towel and isopropyl alcohol, spray onto paper towel and clean thoroughly, reapply grease (could purchase at a reputable PC shop cheaply or order online if not in a hurry). This worked for me when no video was possible with multiple video cards and numerous other failed attempts, the motherboard that I was working on had no onboard graphics so I blamed it on that (i should mention I thought the motherboard was shot because it didn't beep with no RAM installed but was not a factor at all, just wouldn't beep due to an old BIOS that needed updated).
This seems like a long shot I know but I'd try it if nothing else has worked for you.
Evesham Axis PC... | Answered on Feb 27, 2010
Try going into the BIOS on boot and look to see if it is set wrong. To access BIOS, you USUALLY, but not always, tap the Del or F2 key once or twice a second while booting up. This depends on your BIOS and PC model. also, seem to me that if you move your mouse or hit a key the monitor should come out of power save. Try right clicking on the desktop and going to properties. Changing a setting(power options, screen saver, etc.) in there may fix the problem.
Evesham Axis PC... | Answered on Jan 23, 2010
Well there are many resions that causes your PC to run slow -
1. Hard disk drive is short on available disk space.
2. Several software programs have been installed/uninstalled leaving behind bad files and/or confusing the software.
3. Data Corruption.
4. Missing Windows updates / Outdated drivers.
5. Computer is overheating.
6. Corrupt OS.
7. Bad Hardware.
Anyway first of all you can please check the below link for more information (note. this link is only for windows operating system environment)  -
http://onecare.live.com/site/en-us/article/slowpc.htm
Please post comments for more help or information.......
Good Luck!!
Thanks
Method 1: Use Device Manager to scan for hardware changes loadTOCNode(2, 'resolution'); Use Device Manager to scan for hardware changes. After your computer scans for hardware changes, it might recognize the USB device that is connected to the USB port so that you can use the device.
To scan for hardware changes, follow these steps:
  1. Click Start, and then click Run.
    Note If you are running Windows Vista, click Start, and then use the Start Search box.
  2. Type devmgmt.msc, and then click OK. Device Manager opens.
  3. In Device Manager, click your computer so that it is highlighted.
  4. Click Action, and then click Scan for hardware changes.
  5. Check the USB device to see whether it is working.
If scanning for hardware changes fixed the problem, you are finished. If this method did not fix the problem, go to Method 2.
Method 2: Restart the computer loadTOCNode(2, 'resolution'); If scanning for new hardware did not fix the problem, try restarting the computer. After the computer has restarted, check the USB device to see whether it is working.
If restarting the computer fixed the problem, you are finished. If this method did not fix the problem, go to Method 3.
Method 3: Disable and re-enable the USB controller loadTOCNode(2, 'resolution'); Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager.
To disable and re-enable the USB controllers, follow these steps:
  3. Expand Universal Serial Bus controllers.
    Note You might have to scroll down the list to find this item.
  4. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it.
  5. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers.
  6. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled.
  7. Check the USB device to see whether it is working.
Evesham Axis PC... | Answered on Jan 02, 2010
Well, no mention of OS, so i'll guess.....
The files are located on a partitioned portion of the drive, usually a fairly full D drive...
your OS should have a create recovery disk option, usually in system tools, under accessories....
Doc
Evesham Axis PC... | Answered on Sep 27, 2009
HI Dear U just write in google.com "driver" first or second line u will see the free download drivers link OK Best Of Luck.
Evesham Axis PC... | Answered on Aug 22, 2009
well if the unit was not under warranty, you can try to bring it on any authorized laptop service center.
Evesham Axis PC... | Answered on Jul 02, 2009
run the defragmentor...try uninstalling unwanted applications and softwares..make sure you use only original antivirus software and get your desktop cleaned..
Evesham Axis PC... | Answered on May 22, 2009
Evesham Axis PC Desktop Logo
38 questions posted
Top Evesham Computers & Internet Experts
Gar
Gar
Dudeman321
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Evesham Computers & Internet
Most Popular Question
replace power supply
  • Computers & Internet
