20 Most Recent King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P Questions & Answers
a company called SKF has what you need they have a online catalog SKF.com
most Grainger outlets can get these for you (Grainger.com)
King Kutter Pull... | Answered on Sep 05, 2014
First remove the nut on top of the pulley using a 1 1/16 in. wrench or socket. Then you will need to pry the pulley of the shaft using two pry bars. A bit of force may be required. It will kind of pop off when it does finally break loose. Be careful not to lose the half moon key that will still be in the slot on the shaft.
King Kutter Pull... | Answered on May 19, 2011
go to kingkutter.com and download the manual.
hatter1
King Kutter Pull... | Answered on May 26, 2009
Is the machine turning on?
Is the motor / transformer going but the head not?
I can only ASSUME that they are.
Pull it apart and you will probably find that a cam, sprocket or pin of some sort is broken. Some machines use a oscillating transformer action. This coil may be open circuit. A multi-meter check will soon tell you. If this is the case then it is probably cheaper to buy a new or second hand one.
Tools & Hardware... | Answered on Apr 17, 2019
King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P Logo
Popular Tags
20 questions posted
Top King Kutter Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a King Kutter Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • King Kutter Tools & Hardware - Others
Most Popular Question
remove
  • Tools & Hardware - Others
