20 Most Recent
Blade 24- Irwin 7-1/4" X 24t Classic Circular Saw 25130 Questions & Answers
My skilsaw5150 still won't run.
OK I went to a Bosch website to find a breakdown and it could be a couple things. First unplug tool and do you have a volt ohms meter or continuity tester. If so start by checking cord from the plug to the switch and then depress switch and go to brush holders. You might have to remove brushes so it doesn't read across both of them How bad were the brushes you removed, were they burnt looking and if so try and look at the commutator to see any noticable discolored com bars. When you installed the new brushes it is also a possibility that they were sticking in the brush tubes and make sure that the holder pushes into the field connections properly. Let me know if you are still having trouble
Replacement part for Deni model 14300 food slicer
You may be able to find a replacement blade holder for the Deni model 14300 food slicer by contacting the manufacturer directly or by checking online retailers that specialize in replacement parts for kitchen appliances. Some potential sources to check include Amazon, eBay, and the manufacturer's website. Be sure to have the model number and any other relevant information about the part you need on hand to ensure that you find the correct replacement.
2/24/2023 10:25:23 PM •
Blade Saws
Answered
on Feb 24, 2023
Kobalt 24v brushless reciprocating saw seizes when you pull trigger. It clicks (light comes on) but blade won't move
It sounds like you are experiencing an issue with your Kobalt 24v brushless reciprocating saw. There could be a few potential causes for the saw to seize when the trigger is pulled and the blade won't move. Here are a few things you can try:
- Check the battery: Make sure that the battery is fully charged and properly installed in the saw. If the battery is low or not seated correctly, the saw may not have enough power to operate.
- Check the blade: Make sure that the blade is properly installed and tightened. If the blade is not properly installed or tightened, it may cause the saw to seize.
- Check the motor: If the motor is not functioning properly, it could cause the saw to seize. You may need to have the motor checked by a professional if this is the case.
- Check for debris: If there is debris stuck in the blade or in the saw, it could cause the saw to seize. Carefully remove any debris that you find.
If these troubleshooting steps do not resolve the issue, it may be necessary to take the saw to a repair shop or contact the manufacturer for further assistance.
12/27/2022 4:13:28 PM •
Blade Saws
Answered
on Dec 27, 2022
