20 Most Recent
AUVIO Bluetooth Headphones Questions & Answers
Iphone won't find auvio device
Your iPhone might not find the headphones if they have been previously been used with another devices. I recommend holding the call button for 3 seconds until the blue light flashes and your iPhone might find them.
My auvio headphones show a solid red light
Charge your headphones and while they are charging press the call button and the volume up button and you problem is solved. After that just let your headphones charge.
Bluetooth light stays on
I need more details but maybe try holding the call button for 5 seconds until you see red and it will turn off.
Won't connect to bluetooth
Well you have to hold the call button for three seconds and the it will flash and now your phone will find the headphones and it will be successful connecting.
My Audio headset has worked great-but now...it stopped working
Could be the battery has a weak charge! Try running the battery completely flat, recharge fully, then run completely flat, and repeat this cycle about 3 times......This will give the rechargeable battery a revitalised full charge! This is a good procedure for any rechargeable battery as part charging and charging when not completely flat does take its toll on a battery.
