20 Most Recent
Continental CE-PAC1062 Air Conditioner Questions & Answers
115 volt equals how many btu
Apples and oranges.
The 115 volts tells what "quantity" of electricity is needed to run the unit.
BTU's are the cooling capacity of the unit, which usually is about 5,000 for the smallest, up to about 18,000 for the largest.
Over 18,000 the electricity quantity is often boosted to 220 volts because of the larger size of the unit.
Short in plug in cord
If it is the plug itself, you can find a replacement at any hardware store. If you need a new cord, that might be hard to find, but hardware stores have extension wires; just cut off the female end. By the way, if it is the plug you also need to replace the receptacle.
Water leaking
check the whole drain assembly,for clogs an leaks if you notice that there is a clog then treat lines ,,,meaning clean front an back coils after cleaning pour bleach to kill any build up in the system
I have a Continental Portable airconditioning unit that I have to drain every couple of hours?
your problem is that u need a general cleaning ,an with out that u will still have that problem.Now if you have a little knowledge on how to open the system thats somthing u could do yourself..Once u get the system open locate the drain assembly ,make sure that pan an hose both are cleaned out an while you are there go ahead an clean the coils on the unit to prevent any head pressure an that the unit supplies air properly if you dont have any drain cleaner for your unit use ,bleach just a little cap full an pour in pan..an after you get it clean.once a year pour in drain hose ..That should take care of your problem
