20 Most Recent
Iwill KD266 Motherboard Questions & Answers
How to connect the wires in Panel of Board IWILL KD266?
Solutions SFX DC-DC smart power supply is designed specifically for ATX motherboards to be used in an automotive
environment. This Product brings a new dimension to your PC’s mobility. Just get in your vehicle and start the engine; your PC
is ready to go. When you switch off the ignition the PC can go into shut down, standby or hibernate modes automatically, no
switch to fiddle or fuss.
The SFX DC-DC Power supply has a micro-controller that controls and monitors various functions of the power supply
operation. It monitors automobile battery voltage to protect against deep discharge. The Ignition lead is monitored to start the
PC when the ignition is turned on and to implement a safe shutdown procedure. It controls and monitors motherboard signals
to provide smooth power-up and power down sequences. In addition, it also responds to shut down, stand-by and hibernate
modes. The power supply can be programmed to shut down the PC after a delay of up to one hour. The power supply outputs
are monitored to assure proper PC operation. A green LED indicator in the power supply continually reports the power system
status and health. It is also used for troubleshooting.
There are features that are built-in for trouble free and safe PC operation. The input power is protected against transients,
Load dumps and double battery during jumpstarts. PC does not reboot during engine start or cranking.
It also uses state-of-the-art technologies and the most advanced techniques to maximize efficiency, performance and
reliability. Simply put, there are no other PC power supply like it
Iwill kd266 motherboard user's manual
I assume you don't have the software CD anymore either? It includes a PDF copy of the manual.
You used to be able to download the manual from iwill's site, but that was before the site shut down.
Norton tells me that my
yes you can i need to know how much ram yyou have and what windows you have also then i will give you the price of how much the ram will be and give you a link to where you can buy it and then instruct you on how to fit it if this helped be sure to vote i look forward to hearing how you got on please reply with the details
Hello, first of all I need know where the serial
Serial nos of mother board is located in near the ram slot.
Check the ON button if your pc not ON.
check where the jack pin of power button is inserted in motherboard pull it out and short that both pin using wire(touch ones), if again computer not ON then check your SMPS power supply, if again PC not ON then it means your motherboard need repairs no matter the light is ON or NOT.
if u get power light then wire formula will work. Good Luck
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
