Not sure what the crank seal has to do with the stereo, however if it is already apart. Replace the timing belt if it has more than 80,000 kms since new or since last replacement. The tensioner usually will last 300,000 kms or more. If you feel the tensioner the bearing will feel tight or smooth. This is good. If it feels loose, notchie or rocks side to side. Replace it. This will help you decide.
Hi! Please try this to resolve the problem. Open the hood and remove the positive battery connector and let it sit for atleast 5mins. then reconnect it again to reset the system and may resolve the problem. Hope this helps and thank you for using FixYa!
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit.
https://www.google.com/search?q=Xplore+Amp+5553
'year make model' of the vehicle is needed in questions like this please?
Modern vehicle radios are controlled by the Body control Module (BCM) and are used for broadcasting warning beeps and indicator clickers. The beeps an be as innocuous as "do you know your radio is still on"? It can also be caused by your cellphone pinging local transmitters and receiving a confirmation back, or checking in for emails.
JustAnswerhttps://www.justanswer.com > Mercedes Repair
Aug 26, 2010 - What causes a beeping noise to come over the radio speakers? How can it be made to stop? - Answered by a verified Mercedes Mechanic.
1 answer · Top answer: Chat Conversation Started Pete : Hello,I will be glad to try and assist you with this,Welcome ...
Missing: periodic ' Show results with: periodic
iFixithttps://www.ifixit.com > Answers > View > Why+is+m...
Apr 6, 2019 - My speaker has suddenly began making a single sound every few seconds which sounds like a single busy signal on a phone. I have read the manual, ...
11 answers · Top answer: It's low on battery. Plug it in!
Answershttps://www.answers.com > Auto > Auto Parts
Oct 26, 2022 - Press the AS button and hold depressed while turning the radio on. (after 3 secs you should hear a beep. Release the AS button. The display ...
