20 Most Recent
Omega Eskimo 39 In Ice Fishing Auger 8 In Diameter Questions & Answers
Eskimo model 8900 will not fire on starting fluid. Is the coil bad. spark not hot enough
Check it to see if there is a spark at all. You could have a bad plug. The ignition switch could be bad. The module could be bad. I just had a honda 500 that quit running and the connector between the battery and module came loose. If you have a no spark condition find out if there is current to the ignition coil. If not then check all of the fuses to make sure that they are allright. Unplug all electrical and check to make sure that they are clean and tight. If all is ok, then you will need to test individual components.
Cant get my eskimo auger to start
stroke motors do not like ethnol mix fuels as the jets are not right. It could be a cause of it not starting. Wrong oil (engine oil instead of 2 stroke ) will also cause problems as the oil will not pass through the jets.
NEED carb settings for AV520 TECUMSEH
My eskimo ice auger with a 3hp 2 cycle engine. Model number is AV 520. Starts and Idles very well. Does not seem to get enough gas at the high end or want to run wide open. Any ideas?
Bit turns when you try to start
turn down the idle . if carb is set right it should idle and bit shouldn't turn until give it gas with the hand throttle. I have know problem with mine. I start it by myself all the time.
Jiffy ice auger won't start if cold.
I
Hello. I'm kind of "out on a limb " here but my older chain saws and my Jiffy auger's the same. I use the highest octain fuel I can get (at the pump) and I think it helps. These old motors were made to run on real gas.
builderdale
Eskimo ice auger that will not cut through ice
Hello. It couldnt hurt to try shimming the blades.This works for the Mora hand augers.I have an old Jiffy and it cuts better if the triangular point has a good sharp bevel filed on its edges. Happy Fishing!!
