20 Most Recent
Delta TP305 12 - 1/2" Portable Planer Questions & Answers
Sniping
You get sniping with all planers and it will always be the length from the cutter head to the second feed roller. Until the board goes under the second roller it is almost impossible to feed it through and not get some sniping. The same applies to the outfeed side also. Better made (more expensive) planers, table extensions and holding up on the end of the board until the other end is under the second feed roller will reduce sniping somewhat but you'll always have some sniping.
My tp305 removes more wood on the left than on the right. There does'nt seem to be anmy way to adjust this, is there?
These portable planers have a not-negligible amount of flex to them, and you will probably remove a bit of wood even if you run the board through a second time on the same side. But try this to determine if you would want to try to reset the blade height---- run two narrow pieces simultaneously on the left and right. Check the thickness before and after with calipers or something precise. Then switch the two boards and run them again without changing the setting. If it is only cutting on one side, and the thickness was significantly different before the second run, then you might want to adjust the blades in the cutter-head. Good luck.
When feeding a board say
There are a possible number of causes, few of which can be adjusted away.
However, check to make sure the base of the planer, the table under the board is clean and free of pitch and scratches or debris that could interfere with the smooth passage of the board. I use Trewax or some other paste wax on mine to facilitate the board's passage.
You may have a feed roller that is tighter on one side than another, i.e. it is closer to the table on one end than the other end of the roller. It's unlikely there's anything you can do about this, even if you were to make the appropriate hardwood block needed to measure the roller's height at different positions across the table. Small portable planers are prone to this, and often your only recourse is to hold the board straight as it feeds through the machine, by exerting gradual pressure on the side against which it twists.
Finally,it could be the boards that you're feeding into the machine are not flat or have non-parrallel faces to begin with, so the knives of the planer are forced to take a deeper cut off one side of the board. Take a lighter pass and see if the board runs straight. You might be hogging too much off for the planer.
Or the knives could be dull, or knicked, or improperly adjusted and not parrallel to the cutterhead.
But this can be a problem even with industrial quality machines. Normally we just hold the board straight and move on the the jointer or the table saw. It's frustrating behavior, but you can only spend so much time tweaking machines, and then you have to get on with the woodworking.
Hope that helps somehow.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Do you have a owners
go to Dewaltservicenet.com and you can download the owners manual for this tool, it is 48 pages long. Let me know if you need more help and if I have answered your question would you please vote accordingly, thanks
My depth handle turns on
Could not believe there was not a way to "lock" the depth, but it seems that it has been overlooked on this planer... went and took a look at the exploded diagrams and don't see anything...
So... I guess that you will need to devise a way to hold that handle in one place...
For me it would just be a matter on looping a bungee cord over the handle and then hooking it down to the bottom of the planer...that way the handle would not be free to spin as it wanted to or as the vibration tried to spin it....
It really should not take much to hold the handle in one spot.
If you want something more professional looking you could look on the net or in a hardware fro a collar with a set screw that would fit over the screw part....take the handle off and slide the collar down over the screw...once the depth is set then tighten down tha collar and it will keep the screw from spinning open as you are planning...
heatman101
My delta tp 305 feeds
Hi. It means two things to me.
1. You may be trying to get it to cut too much in one pass. Cut less, and cut twice, or even three times. You'll get a smoother finish with less deformities in the wood.
2. When you say ridges, it can be several things, depending on how they appear. If the ridges are running across the board and parallel to the cutter head, this would make me believe in the "you're feeding the machine too much too fast" theory. If the ridges are running long ways down the board, this usually indicated a nick in the blades.
Regards, W/D
How do you replace the belt?
go to Dewaltservicenet.com and type in your model number and you will find a detailed breakdown for this tool. Let me know if you need more assistance
Belt on delta planer
I went to Dewaltservicenet.com and looked at a parts explosion and also the instruction manual for this tool. The manual doesn't say anything about how to do it, BUT the explosion is good quality and should guide you thru replacement. Please let me know if I can help further and if I answered your question would you please rate it accordingly Thank you.
My cricut explore air 2 will not load my mat, what could be the problem?
Cricut Explore Air 2 helps in cutting the beautifully intricate designs using the compatible cutting machines. However, in some situations, you can get the problem where you will not able to use the mat. In this situation, you first make sure you are following the right guide to load the mat, check if the mat is compatible with your Explore Air 2 machine, or your device is not facing any problem.
To get rid of this issue, you have to reset all of your devices and set up the machine once again. Also, check if the mat is not damaged, refer to the Cricut crafting guide for using the mat, use the compatible mat, and more. You can also connect to the Cricut customer support team to get more info from professionals to resolve the issue.
Constraints about making a Jaws of Life model with cardboard, split pins, syringes and plastic tubing.
Question edited for clarity, otherwise this question makes no sense. I presume you mean a MODEL of the Jaws of Life.
Large capacity syringe powering a small capacity syringe with give a significant pressure advantage. The only issue I can think of is the the friction of the secondary piston may be too sticky on the wall of the smaller syringe but if you fill the system with water, you will get true hydraulic results because air can be compressed but water can't
Crafting Clear and Effective Troubleshooting Guides: A Handy Guide for DIY...
Are you tired of scratching your head over malfunctioning gadgets or appliances? Fear not! With a well-crafted troubleshooting guide, you can conquer technical challenges like a pro. Here are some expert tips to help you write troubleshooting guides that shine:
- Know Your Audience: Understand who will be using your troubleshooting guide. Are they beginners, enthusiasts, or experts? Tailor your language and level of detail accordingly to ensure accessibility and effectiveness.
- Start with the Basics: Begin your guide with an overview of the problem and its potential causes. Break down complex issues into simple, easy-to-understand steps. Remember, clarity is key!
- Step-by-Step Solutions: Provide clear, concise instructions for each troubleshooting step. Use numbered lists or bullet points to outline the sequence of actions users should take. Include relevant images or diagrams to enhance understanding.
- Use Descriptive Language: Describe symptoms, error messages, and actions in detail. Avoid jargon or technical terms that might confuse readers. If necessary, define unfamiliar terms or provide a glossary for reference.
- Highlight Common Pitfalls: Anticipate common mistakes or misconceptions users might encounter. Address these pitfalls proactively to prevent frustration and ensure a smoother troubleshooting experience.
- Include Troubleshooting Tips: Offer troubleshooting tips or tricks to expedite problem-solving. Share insights or shortcuts that can help users navigate tricky situations with ease.
- Test and Revise: Put your troubleshooting guide to the test! Walk through the steps yourself to identify any ambiguities or gaps in instructions. Solicit feedback from users to refine and improve your guide over time.
- Update Regularly: Technology evolves rapidly, so it's essential to keep your troubleshooting guide up-to-date. Stay informed about new developments, software updates, or common issues reported by users. Update your guide accordingly to ensure its relevance and accuracy.
Remember, writing an effective troubleshooting guide is as much an art as it is a science. By following these tips and putting yourself in the shoes of your audience, you can create guides that empower users to tackle technical challenges with confidence. Happy troubleshooting!
I need 4 springs for under blades for a pro tech cs6007 contrator series planer
you can find replacement blades (also known as knives) made from a special V2 alloy (high-speed steel) on the MyWoodcutters website. Each set includes 3 HSS blades specifically designed for the CS 6007 model. The cost for a set of 3 blades is $61.50
to replace the springs for the under blades, I recommend checking with a local hardware store or contacting ProTech directly to inquire about availability..
For other parts or accessories, consider exploring online marketplaces like eBay.
