20 Most Recent Black & Decker Black And Decker 12 Volt Battery Charger 5101181 01 Questions & Answers
I have a Black&Decker Smart
junk it there are better and more reliable and simpler units on the market
6/23/2017 3:31:40 AM • Black & Decker... • Answered on Jun 23, 2017
Baught new charger on green light all the time
I would trust that the green light is telling me it is charging "all the time" and in that case DON'T leave it on too long. Go back and check how hot (changed up) the battery is then unplug the charger, better yet take it back to where you bought it for a replacement or get your money back.
10/2/2016 6:58:49 PM • Black & Decker... • Answered on Oct 02, 2016
Battery not charging in electromatic 40
If it does not maintain a charge then replace the batteries.
7/2/2014 12:36:51 AM • Black & Decker... • Answered on Jul 02, 2014
How long does it take to charge a 12 volt battery from a boost
Depending upon the size of your battery and the outdoor temperature, it may take a couple of hours for a full charge from nothing.
6/7/2014 11:50:45 PM • Black & Decker... • Answered on Jun 07, 2014
Transformer
look at your charger,on sticker you have the power it drain.
11/23/2012 3:05:58 AM • Black & Decker... • Answered on Nov 23, 2012
I have a firestorm double
Take a volt meter and test the connections where the battery comes in contact with charger. If you have no voltage, then the charger has failed and needs to be replaced.
8/25/2011 5:14:19 PM • Black & Decker... • Answered on Aug 25, 2011
The charger for my Black
For the price a Dewalt costs, you can buy a few reconditioned cheap cordless drills and keep them all charged up. You will always have a standby. You can also check the pawn shops. With times like they are many people are getting rid of good stuff. You can find a great deat but always use a trustworthy pawn shop and get a receipt with the serial number on it. Theives like pawn shops, too.
Happy Hunting!
12/30/2010 12:49:42 AM • Black & Decker... • Answered on Dec 30, 2010
How do I know if my battery is bad or if my
With a multimeter set it to 12 volt dc and place the leads on the two parts that would be touching the battery. If you see voltage then it is a bad battery.
-David
11/8/2010 8:12:32 PM • Black & Decker... • Answered on Nov 08, 2010
2answers
I have a 12V deep cycle battery for my RockWood
You'll have to figure out the approximate number of hours that you want to use each device (fan, light, etc.) and then find out for each device how much electric it uses (by checking the wattage). Here's a link to a calculator that will tell you how much each device will use.
http://www.alternate-energy.net/batteryamphours03.html
You will also need to know your battery's amp hour rating. In summary, take each device and calculate its run time and then subtract all of them from your batteries total run time.
In practicality, these are all theoretical calculations. If I were you, I would try a simulation of this in my backyard and see how well it works rather than trying this out for the first time in an environment where you have to have these devices. Good luck!
11/6/2010 6:42:43 AM • Black & Decker... • Answered on Nov 06, 2010
Charging light does not come on, is it working or
usually not, but could be one of the LED light burnt out though I don't believe so. Do you have a volt ohms meter that you can check voltage coming from the charger contacts to verify the operation.
10/17/2009 6:58:11 PM • Black & Decker... • Answered on Oct 17, 2009
The red and black clips have come off my battery
Do you have a volt ohms meter? If so you can test the wires and find the correct ones. If not you might want to look at the cord for any sign of polarity, last resort take the cover off the charger and look at the board for the positive terminal going to the cord and trace it out. That is all I can think of to help.
10/8/2009 4:51:30 PM • Black & Decker... • Answered on Oct 08, 2009
The light don't come on and want charge my 12 volt battery
My charger has a fuse located on the circuit board inside the unit....when mine stopped working, it was the fuse...replaced it and it is working fine for one battery, the other blows the fuse every time....bad battery.
5/20/2009 2:46:50 AM • Black & Decker... • Answered on May 20, 2009
I am looking for a manual or parts list for a black and decker U-140 Sander
its listed as a vintage sander may have to source used ones ... ebay ? cant find a user manual online parts might be discontinued not showing up on the parts list Black and Decker Sander Parts 26331537-vy1lstfh3l30zusxkpzc2uyh-1-0.jpg
2/28/2024 6:16:06 PM • Black & Decker... • Answered on Feb 28, 2024
2answers
Aguired a black and decker model 7600 router tool.
They don't have an instruction manual online at the Black and Decker support site, but if you want a look at the exploded diagram, it's here.
Basically there's a collet nut that gets tightened down to hold the bit in place. You've got to loosen it up and you'll be able to pop bits in and out. You've got to have some way to lock the shaft while you're doing this though.
Most modern routers have a spring loaded shaft lock button. While you're holding it in, start turning the collet. When the shaft gets to the point where there's a little hole for the spring lock, you'll probably hear a little click, and the shaft will be locked so you can loosen the collet. If you take your finger off the shaft lock, it pops right back out again so hold it down while you're loosening and tightening.
If you don't see a shaft lock button, you may have a second hex nut at the base and with two wrenches, you can hold the hex nut and turn the collet loose that way.
If this answer was helpful, please give it a vote. Thanks.
12/20/2023 10:50:18 PM • Black & Decker... • Answered on Dec 20, 2023
Black & Decker Black And Decker 12 Volt Battery Charger 5101181 01 Logo
Popular Tags
26 questions posted
Top Black & Decker Tools & Hardware - Others Experts
Paul Carew
Accurate TV Repair...
john h
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Tools & Hardware - Others
Most Popular Question
charger black
  • Tools & Hardware - Others
