20 Most Recent Poulan Pro 18 Inch 400E Chain Saw Questions & Answers
My chain is not cutting
You may have put the chain on backwards. That is possible...
Jim
8/15/2011 4:07:18 AM • Poulan Pro 18... • Answered on Aug 15, 2011
My poulan pro pp400e chain
So the chain stops and the motor still runs. Does it run at high RMP or just idles. It could be the chain brake. My clutch froze up on me after an hour of running. I had to let it cool and then take it apart to free it up.
7/10/2011 4:59:00 PM • Poulan Pro 18... • Answered on Jul 10, 2011
My 18" Poulan is awsome,
When it overheats it may not be getting enoiugh oil. The oiler may be weak have it checked. I too, have a Poulan 18" Chainsaw and I think it is great. Everything I own is Poulan Pro or Troy Bilt. They are simply the best for the price.
12/30/2010 12:38:37 AM • Poulan Pro 18... • Answered on Dec 30, 2010
I HAVE A POULAN PRO 400E ELECTRIC CHAIN SAW, TODAY
I have the same problem --if any one knows please send info
Thanks Ron
12/28/2010 3:28:02 PM • Poulan Pro 18... • Answered on Dec 28, 2010
What is the proper way to sharpen the chain
you can buy a simple kit for a few dollars, there is a jig that holds the chain and a roud file that will be guided through the jig at the proper angle to sharpen the chain
10/31/2009 1:13:36 PM • Poulan Pro 18... • Answered on Oct 31, 2009
Electric Poulan Pro 400E won't run
Loosen the chain as it could have run over something or tightened itself as the chain dried out. But if it won't turn and it just humms or does' nothing the motor may have overheated and locked up. The motor may smell burnt ( like a hot elecrric stove) and it may be melted together. If its halfway new and you have the reciept you can try to exchange it but certain kinds of failures may not let you get an exchange
9/4/2009 5:07:04 PM • Poulan Pro 18... • Answered on Sep 04, 2009
Poulan p3314 hard to pull and jerky
There could be a few reasons why your Poulan p3314 is hard to pull and jerky. The most common reason is that the spark plug is dirty or fouled. This can happen if the engine is left to sit for a long period of time, or if it isn't used very often. Another possibility is that the air filter is dirty and needs to be replaced. What could be causing your Poulan p3314 to be hard to pull and jerky? The most common reason for a hard to pull and jerky Poulan p3314 is a dirty or fouled spark plug. This can happen if the engine is left to sit for a long period of time, or if it isn't used very often. Another possibility is that the air filter is dirty and needs to be replaced. How can you fix a hard to pull and jerky Poulan p3314? The best way to fix a hard to pull and jerky Poulan p3314 is to clean or replace the spark plug. If the air filter is dirty, it will also need to be replaced. I hope this helps!
11/22/2022 3:53:04 PM • Poulan Tools &... • Answered on Nov 22, 2022
Poulan p3314 saw is hard to pull and jerky. i'm unable to get enough pull to fire engine up. Any ideas what problem might be? Repair solutions needed. Thanks
incorrect plug in use where the plug end is hitting the piston seizing piston ring seizing bearing flooding engine allowing raw fuel into combustion chamber causing a hydraulic lock situation remove the plug and if the pull start is normal, it is either the plug or excessive fuel if it spins over freely with out the plug put your finger over the plug hole and pull the cord several times to remove any excess fuel from the system if it is still difficult with the plug removed replace or repair
9/2/2017 11:15:48 PM • Poulan Tools &... • Answered on Sep 02, 2017
Set H&L jets oh a poulan p3314
I believe there is also a idle adjust. adj. both L and H 1 1/2 turns approx from closed (bottom) for initial start up. check video links below, press the helpful button http://www.poulan.com/ddoc/POUO/POUO2004_USen/POUO2004_USen__530165293-01.pdf How To Easily Fix Chainsaw That Bogs Down By Adjusting The Carburetor HOW TO ADJUST POULAN CHAINSAW CARBURETOR .
1/22/2016 10:29:54 PM • Poulan Tools &... • Answered on Jan 22, 2016
I accidently broke the kill switch wire from at the inline connecter. I have 2 small probes (end of wire) from the motor that pulled out of that connector end. The connector from kill switch seems to
Glad you fixed it. They are usually just a simple on off switch and the spark either works with it on or off.
9/26/2012 6:00:52 AM • Poulan Tools &... • Answered on Sep 26, 2012
I have an Inca 343.190 planer / thicknesser with a problem: the in-feed and out-feed tables are not parallel, but I can't find any advice on how to adjust these tables. Can anyone help please?
The best resources to answer this would be the maker themselves, or the woodworking / machine forums. Details in the link. https://www.google.com/search?q=inca+343.190+manual
Automatic Planer jointers thicknesser 343.190 - Inca Parts ...
Incamachines https://incamachines.com > english > inca-spare-parts > a... 343.190 planer thicknesser plane jointers US models 510, 550, 570.
INCA Woodworking Jointer Planer
Machine Atlas https://docs.machineatlas.com > Inca+Woodworki... PDF The INCA Woodworking. Machinery Handbook. With useful tips and jigs for everyone. Mark Duginske, Karl Eichhorn. ????. Edited by INCA Ltd, Teufenthal/Switzerland . ..
4/19/2024 7:07:51 PM • Tools & Hardware... • Answered on Apr 19, 2024
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
3/18/2024 5:15:05 AM • Tools & Hardware... • Answered on Mar 18, 2024
Poulan Pro 18 Inch 400E Chain Saw Logo
Popular Tags
10 questions posted
Top Poulan Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Poulan Tools & Hardware - Others
Most Popular Question
electric poulan pro 400e run
  • Tools & Hardware - Others
