20 Most Recent Bosch 1250DEVS, 6" Dual - Mode Variable Speed Random Orbit Sander Polisher Questions & Answers
0answers
Bosch 1250 devs stopped rotating just makes bussing sound
Check for worn out brushes and damaged armature.
4/25/2013 7:17:20 AM • Bosch 1250DEVS,... • Answered on Apr 25, 2013
2answers
Hi - Looking for a router collet assembly for Bosch 1615evs. Do you have?
this site does not have or sell parts. Manufacturers do not red this looking for sales. Parts are available on line from many vendors.
5/10/2023 12:23:09 AM • Bosch Tools &... • Answered on May 10, 2023
How do i remove pad from snap on air orbital sander
All the other answers are wrong. You get a wrench with the sander. It's thin so it fits between the pad and sander to hold the nut in place while you unscrew the pad.
10/20/2022 3:13:56 PM • Bosch Tools &... • Answered on Oct 20, 2022
I am trying to find a manual for my Bosch pho 200 planer. There are non available to download. Can you possibly assist me? JOHAN
https://manuals.plus/bosch/pho-20-82-corded-compact-planer-manual#axzz7YG6vK5wp http://www.free-instruction-manuals.com/pdf/p3427802.pdf
7/6/2022 11:25:30 AM • Bosch Tools &... • Answered on Jul 06, 2022
2answers
My 3x21 Bosch belt sander will no longer adjust enough to track properly. Is there a fix?
There are a number of reasons why a belt sander will fail to track - Poor quality belts. Physical damage (dropped). Uneven wear of rubber drive roller. When one becomes troublesome it can take a deal of sorting. Best idea if there is no obvious reason is to start by trying an OE belt.
7/13/2020 7:27:51 PM • Bosch Tools &... • Answered on Jul 13, 2020
I have a Bosch model DVS 3107 that runs fine if I am not placing it on the sanding surface, but bogs down when i start to sand. Disassembly revealed that both armature bearings are free. Thoughts?
Just to clarify ..the bearing at the bottom nearest to the sanding pad is good? Also does it just stop and make a humming sound when in use ?
2/4/2018 4:27:35 PM • Bosch Tools &... • Answered on Feb 04, 2018
Can i turn my bosch pex 115a grinder into a sander
Isn't this a random orbital sander.
9/28/2017 6:29:33 AM • Bosch Tools &... • Answered on Sep 28, 2017
?My Bosch 3107DVS sander slows down while sanding almost to a complete stop. Any ideas
Make sure that you have a good set of brushes in there. If so and it continues to happen then the motor is no longer drawing the amount of current it needs to function properly, because it should not slow down like that.
2/15/2017 11:03:04 PM • Bosch Tools &... • Answered on Feb 15, 2017
What type of oil goes in the bosch hammer drill crank case
Not for the little handtools there are 2 different greases depending on the model. But the average hand 5kg Bosch hammer 1 615 430 019 oil 1000ml
1/7/2017 9:52:41 AM • Bosch Tools &... • Answered on Jan 07, 2017
0answers
Bosch 1250DEVS, 6" Dual - Mode Variable Speed Random Orbit Sander Polisher Logo
3 questions posted
Top Bosch Tools & Hardware - Others Experts
vince
john h
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Tools & Hardware - Others
Most Popular Question
bosch 1250 devs stopped rotating just
  • Tools & Hardware - Others
