20 Most Recent RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Questions & Answers
4answers
My Duralast Gold Jump Starter does not take a
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
4/22/2023 9:06:25 PM • RoadPro Road Pro... • Answered on Apr 22, 2023
3answers
I need an online instruction manual for an Everstart 750 model JUS750CE
What the ****** fu***ng hell is wrong with you people always asking for is a manual and you give him all these fu****g spam links
2/9/2023 8:33:02 PM • RoadPro Road Pro... • Answered on Feb 09, 2023
Everstart MAXX 1200A Jumpstarter with AIR COMPRESSER Digital display always on .
not a car and we are not youtube. sorry, learn to search there or google + videos or RTM read the manual
10/23/2022 4:19:30 PM • RoadPro Road Pro... • Answered on Oct 23, 2022
I have a duralast 900 jump starter that reads FL
I called the Service Call Center and they said that "FL" means the battery is fully charged, which is the way it is shipped from the manufacturer.
12/28/2015 7:15:47 PM • RoadPro Road Pro... • Answered on Dec 28, 2015
How do I connect a 5 wire digital Volt/Ampmeter from my solar panel to my battery.
If you can identify which is the voltmeter and which is the ammeter, it should be simple. Say the solar panel has output wires of Red (positive output) and black (negative output). The ammeter goes in series with the load (cut the red wire and insert there). Voltmeter goes between Red (solar panel side usually) and Black. That accounts for four wires. The fifth wire may be an earth ground but I'd be guessing. If you can post a link from the manufacturer, I will comment further.
10/10/2014 6:23:20 PM • RoadPro Road Pro... • Answered on Oct 10, 2014
How do I know the battery status on my Stanley 350
I have a more basic version from Home Depot. From day 1, the charge indicator never worked correctly. Have had it several years now and probably by this time, the battery is just getting weak and needs to be replaced. I found that charging by the cigarette lighter doesn't work too well. Charging by the AC adaptor overnight is the best and I do it every 4 months. Once and a while, I test it by connecting to an old starter motor. If it spins at decent speed, the charge is OK. The cigarette lighter plug connection is also good to use when you need to change the car battery and don't want to loose all your radio presets. It backfeeds the system and keeps all battery powered systems powered when the main battery is disconnected. NEVER run the engine without the main battery connected! Good way to burn out all your electronics.
7/11/2014 6:00:15 PM • RoadPro Road Pro... • Answered on Jul 11, 2014
My Duralast jump starter is dead and when I tried
It will not charge without an adapter suitable for the rated charging amperage. Also,
it must have a ground.
6/26/2014 5:50:46 AM • RoadPro Road Pro... • Answered on Jun 26, 2014
MY pEAK 450 BATTERT CHARGER WONT RECHARGE WHY
The internal battery may be too old to be useful any more.
1/29/2014 4:08:16 AM • RoadPro Road Pro... • Answered on Jan 29, 2014
Need size of adapter
this ( --------------- ) big
12/30/2013 5:40:55 PM • RoadPro Road Pro... • Answered on Dec 30, 2013
What store carry a 450ma adapter for jump starter
radio shack ???
12/30/2013 5:40:38 PM • RoadPro Road Pro... • Answered on Dec 30, 2013
Where to find adapter
stores that sell the brand and model may have the available adapter but I doubt it if they sell them as separate parts for they all come from the manufacturer as a set. or else you may order directly from the manufacturer for the adapter.
12/28/2013 6:08:17 PM • RoadPro Road Pro... • Answered on Dec 28, 2013
RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
59 questions posted
Top RoadPro Air Tools & Compressors Experts
Kardoc
Tami Scott
Tami Scott
Level 1 Expert
Larry Ng
Larry Ng
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • RoadPro Air Tools & Compressors
Most Popular Question
duralast 900 jump starter reads fl
  • Air Tools & Compressors
