20 Most Recent Black & Decker 14.4 Volt Battery Charger #5101181 02 Questions & Answers
3answers
Same problem here.
If you're only reading .18 volts DC at the charger itself, then it's time to replace the charger.
It's probably some inexpensive Electrolytic Capacitors inside the charger that have bit the dust.
Here's info about Electrolytic Capacitors,
1.http://en.wikipedia.org/wiki/Capacitor_plague
2.http://www.capacitorlab.com/visible-failures/index.htm
Both sites relate to computer motherboards and computer power supply's, but know, that there has been a problem with 'Caps' for all kinds of electronic components, no matter what they are, therefore these same visual signs of failure apply. (Sorry about the run on sentence!)
3.http://www.absoluteastronomy.com/topics/Capacitor_plague (Read the entire article, and my statement above will become more clear)
7/1/2016 12:17:38 PM • Black & Decker... • Answered on Jul 01, 2016
3answers
Charger won't charge
The unit is probably bad. Mine just died turned out its the wall wart. The wall wart is a transformer only set up and outputs about 17VAC. The DC conversion is done in the clip. Only option I found was to replace the charger with the new multivolt charger , Upside batteries charge in about an hour to hour+1/2 vice 3 hours.
7/1/2016 12:06:19 PM • Black & Decker... • Answered on Jul 01, 2016
How to disengage the battery from the charger on a b&d 14.4 volt system
Push tabs in battery and slide
7/12/2014 5:36:16 PM • Black & Decker... • Answered on Jul 12, 2014
Lights do not come on
Same thing happened to me recently. The charger (wall transformer) is bad, there is little voltage coming out of the charger base. The circuit inside the base is simple rectifier with LED. Mine is fried from my experiment. If anyone has the resistor R1, R2 values or colored pictures to show the color bars would be helpful.
I thought mine was 52 ohms and 100 ohms respectively...but that doesn't seem right.
At any rate, a simple 14-15VDC 200mA charger could replace the adapter/circuit board altogether.
1/30/2011 1:30:10 AM • Black & Decker... • Answered on Jan 30, 2011
How long do i charge
The charger base automaticly charges the proper length, remove when the light turns green
11/28/2010 7:19:30 AM • Black & Decker... • Answered on Nov 28, 2010
Where to purchase charger for 14.4 V firestorm
blackanddecker.com around $20
10/16/2009 5:26:48 AM • Black & Decker... • Answered on Oct 16, 2009
I am looking for a manual or parts list for a black and decker U-140 Sander
its listed as a vintage sander may have to source used ones ... ebay ? cant find a user manual online parts might be discontinued not showing up on the parts list Black and Decker Sander Parts 26331537-vy1lstfh3l30zusxkpzc2uyh-1-0.jpg
2/28/2024 6:16:06 PM • Black & Decker... • Answered on Feb 28, 2024
2answers
Aguired a black and decker model 7600 router tool.
They don't have an instruction manual online at the Black and Decker support site, but if you want a look at the exploded diagram, it's here.
Basically there's a collet nut that gets tightened down to hold the bit in place. You've got to loosen it up and you'll be able to pop bits in and out. You've got to have some way to lock the shaft while you're doing this though.
Most modern routers have a spring loaded shaft lock button. While you're holding it in, start turning the collet. When the shaft gets to the point where there's a little hole for the spring lock, you'll probably hear a little click, and the shaft will be locked so you can loosen the collet. If you take your finger off the shaft lock, it pops right back out again so hold it down while you're loosening and tightening.
If you don't see a shaft lock button, you may have a second hex nut at the base and with two wrenches, you can hold the hex nut and turn the collet loose that way.
If this answer was helpful, please give it a vote. Thanks.
12/20/2023 10:50:18 PM • Black & Decker... • Answered on Dec 20, 2023
2answers
What does the code F02 mean for a smart battery charger
It means one of two things. Either you do not have a good connection from the charger to the battery, check and clean the clamps and terminals, or the battery has too low a charge. A smart charger needs to measure the existing charge before it will work.
11/10/2023 5:57:51 PM • Black & Decker... • Answered on Nov 10, 2023
Staples for dn418/d16 black and decker staple gun
Try this place. https://www.my-staple.com/articles/agrafes-pour-black-decker-dn418-473.html?lg=en
4/26/2022 10:58:09 AM • Black & Decker... • Answered on Apr 26, 2022
Can I use the heat element of a 1000W blow dryer in a 1000W heat gun?
Yes, the difference is the air flow over the 1000 watt element, blow dryer, uses lots of air, heat gun uses a lesser airflow.
10/8/2021 6:00:12 PM • Black & Decker... • Answered on Oct 08, 2021
2answers
Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
3/10/2018 7:47:06 AM • Black & Decker... • Answered on Mar 10, 2018
Black & Decker 14.4 Volt Battery Charger #5101181 02 Logo
Popular Tags
15 questions posted
Top Black & Decker Tools & Hardware - Others Experts
Paul Carew
Accurate TV Repair...
john h
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Tools & Hardware - Others
Most Popular Question
long charge
  • Tools & Hardware - Others
