20 Most Recent
Javelin Systems Inc Javelin Viper PC Desktop Questions & Answers
Clean install?
use a usb cd drive and set your computer bios to boot from the cd
I need to make an
I would have to say yes because the data for your POS can be found
HERE and it says it has a removable hard drive. Unfortunately it's no longer being sold so support is limited.
Image quality
sounds like your printer buffer may be running out of memory. Try turning the file into a PDF and printing that instead.
Card does not read
Card readers build up magnrtic particles from the cards they read . u might try cleaning it with a blank card that has a rough surface/ladened with alcohol, or a very small q-tip ladened with alcohol to remove the dirt and magnetic residue. too much built up residue can cause, loss of reading ability, and lost sensitivity between the card and the reader.
I'm having trouble with the Javelin J330i printer.
check the feed tires ,the ones that feed the paper/cards into the printer. they maybe slick with paper dust. I recommend taking a cotton dish cloth or rag with some 409 cleaner on it the the feed tires clean all the paper dust off the tires let dry then try to feed card again. sound like the sensor is covered with paper dust, and is giving a false error.
