20 Most Recent Konica Minolta Konica Mino Used Maxxum 2Xi 35mm SLR Autofocus Camera Body Questions & Answers
X300 and x700 no power
These use two of the L44 common button battery. The + sides of the battery (flat) goes towards the body ... the bump goes towards the battery holder. Check the contacts on the body and where the threads (-) contact the body. Not voltage, no work. Assuming you have 4 different batteries, can you check the batteries ? One bad one of two will not allow voltage. I have bought new button batteries that were dead right from the package. Strange two cameras are dead. They have electronic shutters. The LED should light up in the viewfinder when the shutter is slightly pressed.
2/20/2018 6:31:02 PM • Konica Minolta... • Answered on Feb 20, 2018
What is the right battery to Minolta XG-1?
Hi
check the following
Energizer 3V Lithium Camera Battery - EVR2L76BP
Energizer Silver Oxide 1.5V Watch Battery - EVR357-303TS
Duracell 1/3 N-Cell Lithium Battery 1 Pack - DL1/3NBPK
Energizer Silver Oxide 1.5V Watch Battery 3-Pack - EVR357BP-3
Cheers
Tejodhar
1/12/2014 12:03:19 PM • Konica Minolta... • Answered on Jan 12, 2014
0answers
0answers
My father-in-law passed away and has a Konica
Recent resale activity shows the camera with a single lens going for between $40 and $55. The additional lens will add $10 to $15 to the value.
4/1/2011 4:11:09 AM • Konica Minolta... • Answered on Apr 01, 2011
Can u use the lenses of minolta slr camera with
If you have manual focus Minolta lenses, then they are not usable on anything other than other manual focus M35mm Minolta SLR's.
If they have the Minolta autofocus mount then they will physically fit onto any of the current range of Sony Alpha SLR's and also the discontinued Konica Minolta digital SLR's, but there will be some issues:-
  • there will be a 1.5x magnification factor due to picture cropping caused by the digital image sensor being smaller than a 35mm film frame. As an example, a 70-200mm zoom lens will produce an image equivalent to that of a 105-300mm lens if mounted on a 35mm camera. Lens apertures are not affected by the 1.5 crop factor.
  • Earlier Minolta AF lenses relied on the camera body providing the autofocus motor. Later Konica-Minolta and Sony models lack this motor so the lens can only be used in manual focus mode.
  • If you have a later SSM (SuperSonic Motor) equipped lens and want to use it on an Minolta Alpha/Maxxum/Dynax 9 (different model names in different countries), the camera needs a complete additional circuit board which is no longer available.
  • Later Sony Alpha SLR's have far greater electronic communication with the lenses used. Many Minolta lenses will not be compatible and as Sony don't support legacy products there is no fix.
In short, Minolta MD lenses (manual focus) can't practically be used on any modern digital cameras, and Minolta Alpha (autofocus) lenses will physically fit onto a Sony Alpha digital SLR, but will act as if magnified and may not autofocus or work at all on a Sony SLR. But there's no harm in trying.
Sorry there is no absolutely definitive answer for you, but I hope that you now understand why and that you take a moment to rate my reply.
9/19/2010 6:47:46 PM • Konica Minolta... • Answered on Sep 19, 2010
2answers
Looking for a Minolta Maxxum 5 manual
try------- my retrevo-my manuals
11/12/2009 2:56:12 AM • Konica Minolta... • Answered on Nov 12, 2009
CAN NOT OPEN FILM LATCH
If this is an SLR style camera, you need to press a small silver button on the bottom while pulling up on the rewinder knob. If it's automatic, there is a button you have to press on the side latch before you are able to open the film chamber. Some newer cameras will not allow you to open the back unless the film has been rewound, so you may need to insert a battery to rewind the film before you can open the latch.
4/13/2009 12:30:19 AM • Konica Minolta... • Answered on Apr 13, 2009
Mirror lock up
carefully push the shutter curtain to the rewind side. If you look at the camera from the front with the lens off, push the cloth curtain to the right
7/28/2008 7:40:44 PM • Konica Minolta... • Answered on Jul 28, 2008
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old. If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load. I would get it serviced at an aurgorised Minolta repair shop. Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM • Photography • Answered on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
  1. Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
  2. File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
  3. Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
  4. Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
  5. Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM • Photography • Answered on Mar 16, 2024
I lost one of the little rubber ball-like feet off my tripod 1612201. Do you have them available?
We don't have anything available Elizabeth. We are Fixya, and we only supply free information. It would be useful to know the maker as the '1612201' doesn't bring much up and looks like a serial number. Your local camera shop can get them, or you can get online. https://www.google.com/search?q=tripod+feet+replacement //
2/9/2024 6:10:43 AM • Photography • Answered on Feb 09, 2024
Konica Minolta Konica Mino Used Maxxum 2Xi 35mm SLR Autofocus Camera Body Logo
1 questions posted
Top Konica Minolta Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Konica Minolta Photography Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Photography
Most Popular Question
red hue in view finder makes hard see
  • Photography
