20 Most Recent
Bulova Millennia With Vibra-Alarm 98A48 Wrist Watch Questions & Answers
Replaced watch battery on bulova millennia alarm
Watches, well most quartz anyway, are programmed to alert it's wearer to the fact that the battery in the watch is growing weak and needs to be replaced. There are watches that use a 2 second split and then there are those, like my Bucherer quartz that hops at 5 second intervals. Remember, just because you put a "new in the package" battery in your watch does not guarantee that it is new by way of battery power. Some batteries go completely dead while sitting on shelves waiting to be sold. For those of you that don't know, take it from a man of experience, never... ever... ever... store loose change and opened, new or used, coin or watch batteries in the same junk drawer. They will combine chemically to cook off the battery cells like a .22 rounds and pieces can fly pretty fast. Have a great day!
The poblen water inside
Get it dried out as soon as possible as rust starts in as little as 48 hours. Then find out why it leaked. You will need a watchmaker
Looking for instruction manual for Bulova 98A48
I could not find your watch on their web site, perhaps it is discontinued?
You may find a watch that is similar to yours however.
If you go to "Boluva.com", you will find a menu at the top of the screen. Click on "service centre" and you will see a list o watch types; click on "boluva" and you will arrive at a list of instructions.
A search of these might help.
Otherwise try their repair service, who might be able to help you.
The battery was replaced and it was checked by a
If he has to send it back to the factory it means that one of the cogs has failed - Bulova delivers major replacement parts only to their repair shops so an independent repairman can't fix it.
So yes, it appears that it was a correct diagnostic - otherwise it would have fix it himself. And the price is about right , $150m is the price just for the inspection and basic labor, the rest is extra - it depends on what else is damaged: a single ruby will cost you around $200.
The alarm section can't be connected to your present problem, it's been inactive for too long to pose a problem to the main mechanism.
When I pull the stem out to stop the watch, I,am
It sounds like at least one button is dirty, and needs cleaning. Sometimes you can spray some electrical contact cleaner on just the switch and that will work. If it doesn't, take the watch into a Jewelry Repair shop and see if they agree with my assessment. Of course, there could be another problem, but electrical contacts slowly oxidize over time, and this is a pretty common problem.
Good luck, and hope this helps.
Help needd to find out
Pull out the winding stem (crown) when second hand reaches 12 o'clock, set main time by ajusting stem, next press and hold A button "near 9 o'clock" hands will move quickly, when close to matching main time, release A button and press in and out quickly until it matches main time. Next push winding stem in, this will start the main and the sub-hands together for normal time. To set alarm press and hold A button until set time is reached, select B button alarm mode "2 o'clock" for beep or vibra, to turn alarm on/off press C button "4 o'clock" for 1 or 2 seconds, the sub hands will move rapidly until it reaches normal time and alarm will sound 3 times indicating it is set, finally when alarm goes off early in the morning for example you can press any button to stop. To reset alarm press C and it will go back to the original alarm setting.
I have a spare set of instructions if required.
My watch is ticking two
The battery in your watch needs to be changed, this a warning the Bulova Millennia 98A48 gives before battery is drained.
I was wondering where to find the seiral number of
The model sometimes is on the case back or inside the case back and the serial number inside on the movement. Therefore you would have to remove the case back. Be careful if you do this so you do not damage the case. Maybe better to have a shop do this for you.
Small hand on Millennia not keeping time
From your book, start from square one. Second hand to 12 Pull crown to stop second hand.Set sub hands to duplicate main hands (correct time) Push crown in. I'm not that clever , I got the jeweler to do it for me.
