20 Most Recent
Bosch RotoZip Spiral Saw RZ10 - 2100 Questions & Answers
Rotozip video
Try a light penetrating oil on the threads, and allow time for it to work. Sometimes working the nut in both directions, back and forth, a little at a time fill allow the penetrant to lubricate the threads better, allowing it to be more easily removed.
Best regards,
--W/D--
How to put a rotozip rz10 back together
Hardest part is getting the trigger mechanism back in the right position while putting the screws in place. Everything has a slot/groove it fits into before both outside covers can be put together. One side will be easier to hold the pieces while the other simply covers them. A spot of glue (elmers) may help to hold trigger in place and the wires.
Rotozip lock wont release
You may have to split the housing for this. I have seen where the pin can become bent or where the plastic housing becomes worn at the pin and allows it to move around too much. They usually also have a small spring with the pin which may have failed.
Trying to get blade off
Try a little PB blaster penetrating oil and a little more muscle not to much!! Nut might be a tad bit rusted in place. Good Luck....
I purchased a demo model of the RotoZip 10 from my
Hi, W/D here.
Check the brushes first. Demo's get pilfered for small items, and the brushes may have been 'misplaced'. If they're there, then trace your wiring through the switch.
Best regards, --W/D--
