Here is an idea that was posted by another fixya expert (Tha
Mp3 Doctor
). I am taking a chance here and hopefully this will work. His directions also tell how to make sure the bowl is seated correctly. Best wishes.
Remove the work bowl completely and separate the work bowl, lid and
pusher sleeve. Plug the base into the wall outlet and press the on
switch. Use a pen to depress the dark grey or black button on top of the base of the processor. If you don't hear a sound, then call Cuisinart and get it repaired. If you do hear a sound:
1. Put the work bowl on first, making sure the handle is facing front
2. Put the lid on, making sure the hollow feed tube is facing the back of the food processor
3. Put the pusher sleeve in, making sure the sliding lock switch faces toward the front of the processor
Turn the machine on - it should now be working
