20 Most Recent
Cuisinart DFP-14BC Custom Food Processor Questions & Answers
My Cuisinart food processor won't start!
Make sure work bowl handle is locked in so that the handle is facing the front of the processor, and that the feed tube and metal rod of the pusher are facing the back of the processor. If it is assembled in this way and still won't turn on, call Cuisinart for assistance, as you may have concelaed damage to one of the work bowl parts. 1-800-726-0190
2/28/2017 4:39:31 PM •
Cuisinart...
Answered
on Feb 28, 2017
Won't start;
A possibility that the micro switch inside which is actuated when you put the top on......the one you are tooth picking....has become dislodged, or the grooves that the switch hold it in place have broken off. Is there anything rattling inside the mixer which would suggest that a piece of the casing has broken off.
If you can disassemble it to this point where you can see the switch and there is damage around that area which makes the switch loose, you could use some hot glue to hold it firmly in place. Let the hot glue set solid before you use it.....especially as the switch completes an electrical circuit and hot glue in its liquid form s conductive!
Always remember to remove the electrical connection before opening the unit. Failing this, it could possibly be that the switch needs replacing which is a far easier job. Switches are pretty comparable regardless of what brand mixer. Sometimes held in with a screw on opposing corners. So even eBay would probably have one. Good luck. On the bright side, your solution works, but on the dark side, using a plug socket to switch a unit off and on is tricky!
Saranden.
11/24/2013 9:02:39 AM •
Cuisinart...
Answered
on Nov 24, 2013
I can't start my brand new cuisinart 14 cup
Hillary, I have the same problem. Do you think these are the edsels of the food processors. I paid almost $200 for mine, haven't ever used it since I bought it last year. Have you resolved your problem>
3/17/2013 4:04:21 PM •
Cuisinart...
Answered
on Mar 17, 2013
Cuisinart Food Processor Custom 14 turned off
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
6/8/2011 4:39:01 PM •
Cuisinart...
Answered
on Jun 08, 2011
The food processor stops working after use. I know
Not all food processor have a reset button, some don't have. You have to be make sure that the unit is in fit, suited because it will on the interlock switch (the safety switch) before it operates normally.
I hope I give you idea regarding your food processor problem.
3/27/2011 10:32:29 AM •
Cuisinart...
Answered
on Mar 27, 2011
