20 Most Recent
Impact Husky® 1/2" Wrench Questions & Answers
HOW DO I OIL THIS IMPACT WRENCH ?
Pretty much all air impacts are oiled through the air inlet fitting, use 3 to 6 drops this will lubricate the air motor, oil the tool with every use.
Now on the side of the tool you might see a hex plug near the middle or in the front of the tool and might be labeled OIL, that is the one that lubricates the hammer (clutch) mechanism, use a light to medium oil SAE20 or SAE30, this needs to be checked once a month with heavy use or 2 to 3 times a year with light use.
How do i oil my husky air impact wrench?
if its like most of them it goes in the air chuck just a few drops i belive or theres a set screww at the under side by trigger more to the frount not 100 % sure
I have a husky impact wrench, set at 100psi, but
get some air tool oil and put it in the hose connection and manually turn the socket end by hand,the air vanes have frozen in place and can't hold the air in to operate the unit,make sure when you do this squeeze thge trigger to let the oil into the units barrel,then connect to an air supply and try it,you may need to help get it started by hand,then let it run and add some more air tool oil again to keep it lubed
How do you adjust for the desired torque
Normally, there is an adjustment knob at the base of the handle, close to where tha air goes in. Increasing the number setting increases the torque.
Best regards,
--W/D--
Is it normal for oil to spray out of the front of
Yes. Every air tool has an exhaust. On impact wrenches this is usually on the front. Oil is necessary to lubricate the tool and it is delivered through the tool on the same path as the air. But maybe you don't need quite so much oil. If you are trying to keep those nice wheels clean, you can loosely hold a rag over the exhaust. Or some devices have a means to re-direct the exhaust.
Where is the o-ring for the air intake
The problem is in the trigger valve and is a very common problem with these and other brand, some even do that when new! Most people just live with it but you can dissassemble the gun and try.
