20 Most Recent
RTO Forward Reverse Drive Gears:Mgt Questions & Answers
No reverse
well depends on how good of a mechanic you are. The reverse can be replaced. however the transaxle has to be removed. and you went that far... so logically you'd repair the whole thing. a catalog that you can get for free is called Northern Parts. They are out of Iowa. good stuff and offer lots of diffrent stuff and tranny kits inexpensive. (NOT cheap) thats for the parts companies with stuff made in china. Or call a auto salvage yard and see if they have a used one.
The ram on my porta nailer is not returning
Remove the ram cover, using an old blunted nail carefully drive the pin back to the up position. Disassemble the gun and inspect both the drive pin and the rails for metal burrs file them off if necessary.
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes.
Read your user manual for more information.
