20 Most Recent Remington PowerMower 17-Inch 60-Volt Cordless/Corded Electric Combination Lawn Mower Questions & Answers
Corded mower starts and trips circuit switch immediately & will not stay on?
There is a short in the system . The safety device is kicking in check cord for brakes or nics
7/10/2014 4:38:02 PM • Remington... • Answered on Jul 10, 2014
How do I repair the charge switch. When placed on charge the charging light pulsates on/off.
it might be the charger is bad if you can use a voltmeter check and see if continuosly get volts from charger try that first
7/8/2014 2:32:14 PM • Remington... • Answered on Jul 08, 2014
0answers
Cordless mower
Be the first to answer 10/1/2013 4:44:03 PM • Remington... • Posted on Oct 01, 2013Be the first to answer
0answers
2answers
I have the Remington Cordless
The Remington battery has 5 Alkaline battery cells. The model batteries are Yuasa NP5-12T, NP 5-12T .250 terminal or Equivalent. It is a very Easy R & R job. Takes about 10 minutes. You should be able to pick up the batteries for around $10 - $15 each.
8/27/2011 12:04:03 AM • Remington... • Answered on Aug 27, 2011
I have lost the key
You can do this ,but why take a chance of burning up your mower. You should be able to buy a key for this unit from your local dealer. I believe these keys are all of same cut, like a light switch. this way if you can con someone else into mowing your lawn, they can't say I'm not mechanical and don't know how to jump wires, or worst , see first sentence.I feel this will be the easier way. GOOD LUCK.
6/17/2011 5:48:30 PM • Remington... • Answered on Jun 17, 2011
How do you remove the axle cap on a Remington
those you have to break off and replace with a new cap, because when you put them on the barb in the cap digs into the shaft to help hold it on
4/14/2010 10:39:57 PM • Remington... • Answered on Apr 14, 2010
The front right wheel repeatedly comes off because
Can you drill a small hole down through the end of the axle and put a washer and cotter pin to keep the wheels on?
Can you attach a flat piece of plastic or aluminum sheet under the grass catcher to prevent the bag from wearing as it slides along?
Next ....use the best oil you can get......in the engine.......they are also not made as well as they used to be (service life has been reduced ) so take extra good care of it.
9/4/2009 11:31:23 AM • Remington... • Answered on Sep 04, 2009
2answers
B&D CMM1000 keeps stalling
take out your battery take it to an auto parts store and, have it charged and, load tested with a carbon pile tester this should be a free test
6/23/2009 11:11:43 PM • Remington... • Answered on Jun 23, 2009
Batter life in the second season
When batteries are only used seasonally, and they are stored, they can become damaged from weather or from storing them when they are not fully charged. In general, batteries used seasonally will have a shorter lifespan, so it sounds like you likely need a new battery. Check out http://www.batteryinternational.com/electric-lawn-maintenance-batteries.html for a replacement, and be sure to charge it fully before storing.
6/23/2009 5:19:27 PM • Remington... • Answered on Jun 23, 2009
Where can I find a replacement throttle cable for a Remington Rodeo chain saw? The part has been discontinued and I don't have the original. The original part was MTD-753-06409.
This is what it looks like. The only unusual thing is the funny L-Shaped connector and the long length of bare cable which looks like the outer sleeve is held by the oval piece. If you have that oval piece is is an easy replacement. A local motorcycle shop could make you one, or try Jack's Small Engines, he is the expert. https://www.mower-atvparts.com/Remington-Chainsaw-Throttle-Cable-753-06409_p_3393.html https://www.google.com/search?q=Remington+Rodeo+chainsaw+replacement+throttle+cable ..
3/23/2024 12:11:20 AM • Remington Garden • Answered on Mar 23, 2024
Remington 4620 fuel line diagram
Check this out https://www.google.com/search?q=Remington+4620+fuel+line+diagram&rlz=1C1ASUM_enPH918PH918&source=lnms&tbm=isch&sa=X&ved=2ahUKEwi1mr7S-s72AhXSsVYBHUBpCcMQ_AUoAXoECAEQAw&biw=1517&bih=736&dpr=0.9
7/28/2023 2:41:16 AM • Remington Garden • Answered on Jul 28, 2023
My Remington leaf blower is leaking engine oil from around carb. ?
it is a 2 stroke engine, only oil should be mixed in gasoline.
10/27/2022 3:47:26 AM • Remington Garden • Answered on Oct 27, 2022
How to replace pull rope on Remington rm2510
Here is a helpful video that will show you how. https://www.youtube.com/watch?v=2eSWBmhlrxM
5/27/2022 11:42:24 AM • Remington Garden • Answered on May 27, 2022
2answers
2answers
How to fix oil tank leak?
It must have a crack in it? Remove it, check, replace it. https://www.google.com/search?q=Remington+pole+chainsaw+oil+tank+replacement ..
12/7/2021 5:17:18 PM • Remington Garden • Answered on Dec 07, 2021
Remington PowerMower 17-Inch 60-Volt Cordless/Corded Electric Combination Lawn Mower Logo
Popular Tags
16 questions posted
Top Remington Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Remington Garden Expert? Answer questions, earn points and help others
View Most Popular
Remington Garden
  • Remington Garden
Most Popular Question
remington cordless
  • Garden
