20 Most Recent
Swisher 60" 13 Hp Trailmower #T1360h Questions & Answers
Swisher manual
I BELIEVE IT'S 22 INCHES I JUST REPLACED MINE, SEARS HAS THEM OR YOU CAN GET THEM AT SWISHER.COM WITH PART #6046 FROM THE MANUAL OFF THEIR WEBSITE. I'M FINDING I HAVE TO ORDER EVERYTHING SO I'M GETTING 2 OF WHATEVER I NEED AT THE TIME
How do you change the engage belt ?
OK TAKE OFF THE 2 TOP INSPECTION COVERS SHAPED LIKE A "V" THEN YOU'LL SEE THE BELTS, REMOVE THE 1/4-20 NUTS HOLDING THE BELT GUARD ON UNDER THE HOUSING TO REMOVE THE BELT, BE CAREFUL NOT TO OVER TIGHTEN THE BELT TENSIONER IT COULD CAUSE UNDO STRESS ON THE PULLEY BEARING. REASSEMBLE IN REVERSE
Once engaged and start mowing, you can mow for
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
I need replacement parts for my 60
I RECENTLY BOUGHT A USED SWISHER FOR $700 13.5 HP 60 INCH I BELIEVE THE MODEL IS 1340D? I'M HOPING I DIDN'T GET RIPPED OFF AND THIS IS SOMETHING SIMPLE..I THINK THAT'S THE MODEL NUMBER I'M NOT EXACTLY SURE THE STAMP O N THE SIDE ISN'T TO LEGIBLE , ANYWAY WHEN I SPRAY STARTING FLUID INTO THE AIR FILTER IT RUNS BUT THEN STOPS. IT HAS A NEW BATTERY, FUEL LINE AND FILTER AND I JUST TOOK THE CARBURETOR OFF AND SPRAYED IT OUT WITH GUNK CLEANER TO NO AVAIL. THE FLOAT BOWL WAS REALLY CRUDDY. I'M WONDERING WHERE I CAN GET A NEW CARB? ARE THEY AVAILABLE? IF SO WHERE? THANKS
Run a little and blow the fuss?
I RECENTLY BOUGHT A USED SWISHER FOR $700 13.5 HP 60 INCH I BELIEVE THE MODEL IS 1340D? I'M HOPING I DIDN'T GET RIPPED OFF AND THIS IS SOMETHING SIMPLE..HOWEVER I'M NOT EXACTLY SURE THE STAMP O N THE SIDE ISN'T TO LEGIBLE , ANYWAY WHEN I SPRAY STARTING FLUID INTO THE AIR FILTER IT RUNS BUT THEN STOPS. IT HAS A NEW BATTERY, FUEL LINE AND FILTER AND I JUST TOOK THE CARBURETOR OFF AND SPRAYED IT OUT WITH GUNK CLEANER TO NO AVAIL. THE FLOAT BOWL WAS REALLY CRUDDY. I'M WONDERING WHERE I CAN GET A NEW CARB? ARE THEY AVAILABLE? IF SO WHERE? THANKS
Mower has power won't start
either the coil contacts r gummed up or rusted over or the carb needs to be cleaned out, the needle attached to the float is usually the issue in carb problems
