20 Most Recent Lisle Oil Pressure Sending Unit Socket for GM # 13150 Questions & Answers
2002 ford windstar 3.8L oil sending unit location
-Most car it locate around the oil filter. Good Luck Mai
3/27/2014 2:31:36 PM • Lisle Oil... • Answered on Mar 27, 2014
How to change oil sending unit 2000 plymouth voyager 3.0l
location of oil pressure gauge 2000 ply voyager
12/9/2010 11:56:26 PM • Lisle Oil... • Answered on Dec 09, 2010
My 1981 Chevy Malibu classic (v6) has an oil leak
Any Chevy parts department dealership will tell you what this part is. They have photos to go by
3/12/2010 12:10:21 PM • Lisle Oil... • Answered on Mar 12, 2010
2answers
My 1988 suburban is leaking oil but only when it's
If it is leaking as steady as you say when the engine is running, it could be coming from several places you can check. Raise and block the vehicle good and steady enough to where you can slide under it with a good strong light. Check the oil drain plug, pan gasket, oil filter may have a hole in it from a rock flying up, the sending unit should be on the side of the block. It could be the rear main seal, but Its doubtful as you say its a steady stream when its running. You shouldn't have a problem finding it if its a steady leak, you will just have to look where its running down with the engine on. Keep me posted, and good luck.
Shastalaker7
2/1/2010 5:41:44 PM • Lisle Oil... • Answered on Feb 01, 2010
Locate the oil pressure sending unit on
on a 60 series detroit its behind the lower left rear of engine near steering column
10/18/2009 2:36:44 PM • Lisle Oil... • Answered on Oct 18, 2009
2answers
WHERE IS THE OIL PRESSURE SENSOR LOCATED FOR A
It is about 3 inches long with an electrical connector on the end of it. It is back by the right hand side of the distributor. Hard to see.
9/22/2009 2:12:51 PM • Lisle Oil... • Answered on Sep 22, 2009
Rf tech 433mhz manual model 217S31
I want to use an old sensor forgiven during 30 years. I have no more manual, off course. Thanks for your answer
3/26/2024 11:42:40 PM • Measuring Tools... • Answered on Mar 26, 2024
What are the readings on a meoisture meter measured in?
Most moisture meters measure the moisture content of wood or concrete is measured in percentages. So if the reading says 15 that means that there is a content of 15% moisture in the concrete.
3/16/2024 7:34:55 AM • Measuring Tools... • Answered on Mar 16, 2024
How do I change the temperature display on a Digitech XC-0366 weather station from Degrees F to Degrees C?
Pressing the - (minus) button on the back toggles temperature units. Pressing + (plus) toggles barometric pressure units.
2/19/2024 4:57:31 AM • Measuring Tools... • Answered on Feb 19, 2024
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
1/21/2024 4:20:12 AM • Measuring Tools... • Answered on Jan 21, 2024
DSE Z111 Weather Station: Is the wireless sensor available for sale?
Unlikely unless you know the secret maker name and can find them in China. At the moment, no one has heard of it apart from here on Fixya. All questions need FULL 'make model (what it is)' please. https://www.google.com/search?q=dse+z111 ..
1/20/2024 1:59:56 AM • Measuring Tools... • Answered on Jan 20, 2024
How can I adjust the time on my weather station model #sgr72914?
  1. Access the Time Setting Mode:
    • Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
    • Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
  2. Adjust Hour and Minutes:
    • Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
    • After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
    • Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
  3. Confirm the Time:
    • Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
  4. Check the Time Display:
    • After setting the time, check the display to ensure that the time is displayed correctly.
1/7/2024 9:28:03 AM • Measuring Tools... • Answered on Jan 07, 2024
Starrett Tape Measure. Can I Replace a 1.5 volt Battery with a 3.0 volt Battery in it?
Question edited for clarity. Question moved from Motorcycles category. Of course not! You will burn out all the electronic components. You can't just double the voltage. Conversely you can't put a 1.5 volt battery in place of a 3 volt one. Get the proper battery. https://www.starrett.com/contact-us# ..
12/20/2023 4:55:24 AM • Measuring Tools... • Answered on Dec 20, 2023
Ascot Weather Station. Instruction for reset times please.
Ascot weather station manuals
Manua.ls https://www.manua.ls > Ascot > Weather station You are currently on the Ascot weather station manuals page. Choose one of the products to go directly to the manual for this product.
Ascot weather station user manual
Manuals.co.uk https://www.manuals.co.uk > Ascot > Weather station For those looking for a simple and straightforward setup, Ascot Weather Stations provides a quick start guide with step-by-step instructions to get you up and ...
User manual Ascot AUK-WS-32 (English - 6 pages)
Manua.ls https://www.manua.ls > weather stations > Ascot To install and set up the Ascot AUK-WS-32 weather station, you should begin by securely mounting the sensor unit in an elevated outdoor location, ensuring it is ...
Ascot GT-WS-06s user manual (English - 40 pages)
Manuals.ca https://www.manuals.ca > weather stations > Ascot User manual. View the manual for the Ascot GT-WS-06s here, for free. This manual comes under the category weather stations and has been rated by 2 people ...
Ascot Weather Station User Manuals Download
ManualsLib https://www.manualslib.com > Brands > Ascot Manuals Download 1 Ascot Weather Station PDF manuals. User manuals, Ascot Weather Station Operating guides and Service manuals ... Operating Instructions Manual.
12/10/2023 5:27:32 PM • Measuring Tools... • Answered on Dec 10, 2023
Ascot Weather Station. Instructions for operation please?
12/10/2023 5:08:32 PM • Measuring Tools... • Answered on Dec 10, 2023
AcuRite Professional Weather Center 01602BPDI. It eats the outside batteries. Batteries last about 2-3 months till low battery power shows inside with -40 degrees plus other false readings.
My National Geographic Weather Station is the opposite. The outside sensor only indicates the temperature, but the single CR2023 battery lasts a year. The inside unit on my desk lasts around 5 - 6 months and lets me know if needs a battery by showing the outside temperature as ' -- ' Although the manual says 'rechargeable batteries are not recommended', I would try 4 Sanyo Eneloop batteries. Or you could contact Acurite Support and ask them if your battery use is excessive?
01602BPDI - Professional Weather Station Instructions
AcuRite.com https://www.acurite.com > 01602-instructions Professional Weather Center model 01602BPDI. Questions? Contact Customer Support at. (877) 221-1252 or visit www.AcuRite.com. SAVE THIS MANUAL FOR FUTURE ...
12/10/2023 5:06:00 PM • Measuring Tools... • Answered on Dec 10, 2023
Lisle  Oil Pressure Sending Unit Socket for GM # 13150 Logo
21 questions posted
Top Lisle Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Lisle Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Lisle Measuring Tools & Sensors
Most Popular Question
  • Measuring Tools & Sensors
