20 Most Recent
Target Portable Masonry Saw PS1455 Horsepower: 5 1/2. Blade Guard Capacity: 14 Questions & Answers
WHAT KIND OF BLADE GOES
As long as the blade is rated for concrete/masonary (depending on the material being cut, and the blade is a 5 1/2 in, there should be no issues with it/them being on your saw. Every company would like to see their own products used, but that isn't always practicle. Be sure to read the lable as some blades have a specific ratational direction for installation.
Hope this helps.
My target wet saw, on top of the motor has a part
We are currently experiencing a problem with the target TA10100 wet saw. It will start up and immediately shutdown. The local authorized tool repair said that the part encased on the top of the Baldor motor is called a capacitor. we have yet to find out if this is the cause of the problem. Hope the information helps you because so far it hasn't helped us.
10/27/2014 8:56:19 PM •
Target Saws
Answered
on Oct 27, 2014
The saw wants to start
If you have access to an ammeter, check the draw when the saw starts. I don't know what the rating of the saw is but I doubt it's more than 30A. If the startup draw is more than 30A the saw may have a short in the starting circuit. If it's less than 30A the breaker may be bad; change the breaker and retry.
6/27/2011 5:56:40 PM •
Target Saws
Answered
on Jun 27, 2011
Need Parts breakdown for this model on a Target
fyi, target tile saws and felker tile saws are made by the same company, and you can find both of them on line. your best bet is to take your saw to a tile distributor that sells saws and they will get what you need , good luck
7/8/2009 8:47:18 AM •
Target Saws
Answered
on Jul 08, 2009
Wobble blade /rough cuts
You may wanna check the Conveyor Cart Wheel. Replacing this wheel maintains smooth rolling action which contributes to straight, chip-free cuts.
It costs for only about $28.72. Here, you may check this link if you wish to buy the Conveyor Cart Wheels:
http://www.diamond-blades.net/target_tile_saw_access.html
Unfortunately, I couldn't find any service center where you can bring your Target Tile saw for repair. But you may check the manufacturer's contact number on the user's manual.
Have a great day!
5/30/2009 10:47:41 AM •
Target Saws
Answered
on May 30, 2009
Need the Brick Carriage Rolling Bearings
i dont know where your located at, but when i need any parts for my tile saws i get them at the tile shop, that sells me the tile, most good tile distributors sell tile saws and most carry parts for saws targets a great saw and a good tile store will probably have those roller bearings in stock.good luck.chad
5/23/2009 9:13:37 AM •
Target Saws
Answered
on May 23, 2009
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM •
Saws
Answered
on Apr 10, 2024
