20 Most Recent
Briggs & Stratton Intek Snow Horizontal Engine 7.5 Hp, 1in. X 2 27/64in. Shaft, Model# 12D412 0009 E1 Questions & Answers
What is the air gap
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiljOH95IH9AhUbk4kEHZiNBDsQFnoECAcQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft7580947-air_gap&usg=AOvVaw2A3X0d4QjiGVVG4XNf9J0X
2/6/2023 9:00:22 PM •
Briggs &...
Answered
on Feb 06, 2023
No compression 7.5 briggs ohv
take 2 foot of 1/4 fuel line or 5/16 fuel line. screw it into the spark plug hole. if not fit bevel end with grinder or knife. BLOW while slowly turning engine. should come out intake, then exhaust then during compression and power stroke no valves open. If leaks out a valve tap the top of the valve with a screw driver during top dead center power thru the spark plug hole to seat it. if it leaks out the crank case you have bad piston/cylinder rings.
8/31/2014 2:52:20 AM •
Briggs &...
Answered
on Aug 31, 2014
Backfires thrue carb
You may have an intake valve staying open or the spark timing may be off from a slipped flywheel and key. Can spray liguid wrench in the intake to coat valve stem . You would have to take off the flywheel hold down nut and pull starter engage ring to see if the groove in the flywheel matches the groove in the crankshaft. Ive had blowers, weed eaters, tillers and all kinds of small engines break a flywheel key for no apparent reason. Sometimes they are just a little loose and wear out or snap.
1/3/2013 8:31:44 AM •
Briggs &...
Answered
on Jan 03, 2013
Briggs & Stratton 7.5 HP
I would replace the sparkplug making sure it is gapped properly and put a new air filter on the engine.
3/18/2011 10:23:38 PM •
Briggs &...
Answered
on Mar 18, 2011
Fuel in crankcase
The fuel in the crank case is caused by bad rings or scratched/worn piston walls it the only way fuel can reach the crankcase unless you pour it in to the oil fill. The fix is to overhaul the engine. Thanks for using FixYa. Have a nice day. Jeff
6/2/2010 12:32:30 PM •
Briggs &...
Answered
on Jun 02, 2010
