20 Most Recent
DeLonghi Pinguino PAC-260 Air Conditioner Questions & Answers
The PAC-260 runs for a few minutes, then I hear
Hi, what this reset is for is high head pressure. Its building up high pressure and going off releasing this pressure and tripping the switch. I'm not sure if this is water cooled or has a fan in the back for air cooled. If you can get to the back coil, condenser coil and give it a good washing out with a garden hose to clean it, this will solve your problem if its air cooled only though. Try this to see if it does. If not let me know and we can go from there.
Sincerely,
Shastalaker7
12/12/2013 4:07:37 AM •
DeLonghi...
Answered
on Dec 12, 2013
Not cooling
have you checked your filters to see if need cleaning
10/9/2013 4:56:32 PM •
DeLonghi...
Answered
on Oct 09, 2013
EXHAUST AIR IS COOL NOT HOT
This is definitely weird. The exhaust duct (or the connecting tube) must have came off , and you're feeling the recirculated air.All air conditioners (all) have to condense the refrigerant (cool the gas and it becomes liquid) in their condenser. The heat has to go somewhere, usually to the atmosphere and not in the conditioned space.
8/26/2013 5:09:43 AM •
DeLonghi...
Answered
on Aug 26, 2013
How to i get th case of a delonghi model pacan125hpec open?
:To open the case of a DeLonghi model PACAN125HPEC, locate the screws on the back of the unit and remove them. Once the screws are removed, carefully lift the back panel, being careful not to damage any of the internal components. The case should then open and you can access the internal components.
Delonghi hifi heater keeps beeping control board green light
So, it sounds like your Delonghi hifi heater is giving you some trouble, man. The constant beeping and the green light on the control board, it's like it's trying to tell you something. My guess is that there's something funky going on with the thermostat. The beeping is probably the heater's way of saying it can't maintain the desired temperature because the thermostat isn't working properly. And the green light, it's like the heater is still getting power and trying to do its thing, but the thermostat is holding it back.
One thing you could try is checking the thermostat settings and making sure they're all good to go. If the settings are chill, but the problem persists, it might be time for a new thermostat. You could also try unplugging the heater for a bit and then plugging it back in, see if that helps reset the system.
If all else fails, it's best to reach out to Delonghi's customer service or maybe even a professional technician to take a look and give it a tune-up. It's not always easy to fix these things ourselves, so don't be afraid to ask for help.
