20 Most Recent
Casio Watch Edifice Eqw-m1000db-1aer Man Black Questions & Answers
Please how to fix the DST
A supported Fix it solution is now available from Microsoft to enable the first transition from DST for the Ramadan observation on June 26, 2014. You can download the Fix it solution by clicking the one of the following Fix it links, depending on your operating system.Make sure that you have the latest Windows cumulative update for your time zone and DST installed before you run this Fix it solution.
Half hour lag
Some watches can display dual times (two values) usually off by an integer number of hours + 30 minutes, Read the manual to set the digital display time then correct the analog display. Or just use one of the two.
To set the time
Since you neglected to specify the model of your Casio watch, I can only suggest you enter it into the search box
here to download a copy of the manual.
Casio module No. 5069 time setting
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:http://ftp.casio.co.jp/pub/world_manual/wat/en/qw5069.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.See page 1 of the manual in the TIMEKEEPING - TO SET THE TIME AND DATE section for detailed instructions and illustrations about setting the time on that watch.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
