20 Most Recent
Electric Delco MB1718 Mini Brute 1700 Psi Hot Water Pressure Washer Questions & Answers
My cd player dose not work
the reader may have dirt on it or may be
out of alignment.Get a can of cleaning spray
from radio shack that is approved for
electronics and lightly spray any dirt of the
sensor
From an alternator ,there are tree wires .wihs
Near the spade terminals, the rear housing should be marked #1 and #2. Some aftermarket housings are not marked and others may be worn off. So if your alternator housing is unmarked, look from the rear of the alternator: the #1 terminal is on the left and the #2 on the right. You only need an ignition wire to the #1 terminal to make an Si series alternator work. The #2 terminal is for voltage sensing, and is optional. The #2 voltage sensing terminal allows the voltage regulator to sense the battery voltage so it knows when to turn the alternator on and off. The #2 terminal, if it is not used, causes the regulator to revert to internal sensing and pick up the battery voltage at the main battery wire on the back of the alternator. Some alternators are wired with a jumper from the #2 terminal directly to the battery connection at the back of the alternators, but this is not needed.
go to site below ALL about alternators.
http://www.alternatorparts.com/FAQ.htm#how_to_wire
I disconnect the battery from my truck and when i
Is this a radio based on security for GM radios from the 90's with the special code? Look in an owners manual for specifis instructions. If you go fishing for a code, you have the potential of totally disabling your radio. You must follow the specific instructionf for this radio. My Chevy has the same - trust me when I say dont go fishing for the code!
let me know what happens.
Radio in safe mode
you can obtain the unlock code from your local dealership service center
Lost radio code serial number GM150010323996
Your radio is made by SIEMENS/VDO/DELCO and unfortunately DELCO codes are not obtainable for free (using the Serial Number) from anywhere on the Internet as access is required to the original factory database which is only available to the Main Dealer or one the larger professional Decode Services.
The alternative is for your radio to be taken/posted to a Decode Service or your local Car Radio / Audio Shop who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
When you want to fix network problem because my
Try powering down everything. Then start with your modem, then your router, then your computer.
If problem persists, try plugging your computer directly to the modem. See if it works. If not, problem is with your modem and you should contact your carrier.
If it's working, try plugging the computer to the router. If it's working then the router is working and your wireless is your next target.
Try navigating with your phone. If your phone works, problem with your computer's wifi.
11/22/2013 12:34:29 PM •
Electric...
Answered
on Nov 22, 2013
