20 Most Recent Leica Disto A6 Laser Distance Meter Questions & Answers
Disto error code 290
11/19/2023 2:29:06 PM • Leica Disto A6... • Answered on Nov 19, 2023
Owner manual HTCL - HK40
owner-manual-htcl-hk40-3iz3u2qppxews414errgtehb-4-0.jpg The Leica Disto A6 is not the same instrument as the HTCL HK40. Here's a picture of what the HK40 looks like.
6/24/2019 6:02:34 PM • Leica Disto A6... • Answered on Jun 24, 2019
Does not measure distance
Put in new batteries, clean lens, and calibrate. If this does not work, type " Leica Disto A6 Laser Distance Meter user manual " into computer search engine. It will bring up sites for manual.
5/16/2016 11:41:14 PM • Leica Disto A6... • Answered on May 16, 2016
Always get error 279 on
Put in new batteries and clean lens and calibrate if it has that function. If that doesn't work, Type the " Leica Disto A6 Laser Distance Meter user manual" and it will bring up sites to manual.
5/16/2016 11:08:52 PM • Leica Disto A6... • Answered on May 16, 2016
HTCL HK 40 User Manual
Type " HTCL HK 40 user manual " into your computer search engine, it will bring up sites you can go to, to get manual.
5/16/2016 11:02:54 PM • Leica Disto A6... • Answered on May 16, 2016
HTCL HK 70 User Manual
Type " HTCL HK 70 user manual " on your computer search engine. It will bring up sites to find user manual
5/16/2016 10:57:27 PM • Leica Disto A6... • Answered on May 16, 2016
Why is it showing on the Screen info 206
Put in new batteries and clean lens and calibrate.
5/16/2016 10:54:21 PM • Leica Disto A6... • Answered on May 16, 2016
Code error 279
Remove old batteries, put in new batteries, clean off lens.
5/16/2016 10:50:37 PM • Leica Disto A6... • Answered on May 16, 2016
2answers
After I changed the batteries
MY LEICA DISTO D5 SCREEN DOES NOT LIGHT UP ALTHOUGH THERE IS LEISER AND READING. HOW DO I RECTIFY THIS.
6/15/2015 12:56:57 PM • Leica Disto A6... • Answered on Jun 15, 2015
3answers
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
5/13/2015 6:21:17 PM • Leica Disto A6... • Answered on May 13, 2015
I need a free one
I need a free house, wanna trade
3/19/2011 7:30:35 AM • Leica Disto A6... • Answered on Mar 19, 2011
I have a Disto A6 that i've been using and I love
all you need to do is unscrew the disto at the bottom remove it from the case and push the band (wires) that connect the screen to the unit. I had the same problem and just fixed it.
1/19/2011 12:54:41 AM • Leica Disto A6... • Answered on Jan 19, 2011
Dropped device and cracked read out screen. Can I
I heard of a guy in Houston, TX that will replace them, but I searched the internet and couldn't fine any info. I'd try where you bought it for advise. Maybe the factory is your only solution. good luck!
2/1/2010 2:51:06 AM • Leica Disto A6... • Answered on Feb 01, 2010
Leica DISTO classic5. non si accende
English language please.
2/13/2024 4:22:36 PM • Leica Measuring... • Answered on Feb 13, 2024
I am working with leica ts 407 when measuring distances it shows EDM error and not measuring the distances
It's a common issue of this EDM generation, when the instrument is more than 10 years old. Try to check if ALC motor spin freely. Good luck! Carlo Alberto
11/25/2023 6:30:02 AM • Leica Measuring... • Answered on Nov 25, 2023
Leica Disto D3a auto cycling?
You are the only person to have this happen. Contact Leica direct. https://www.google.com/search?q=Leica+Disto+D3a+auto+cycling ..
9/27/2023 12:46:02 AM • Leica Measuring... • Answered on Sep 27, 2023
Leica Disto A5 does not measure with the main button, but it does measure with the timer
It's possible that the main button may be malfunctioning or broken, which is preventing it from activating the laser. Here are a few troubleshooting steps you can try:
  1. Ensure that the laser is not obstructed or dirty. Use a soft, dry cloth to wipe the lens clean.
  2. Check the battery contacts and make sure they are clean and properly aligned. You can clean the contacts with a cotton swab and rubbing alcohol.
  3. Try resetting the device by removing the batteries for a few minutes and then reinserting them.
  4. Check the user manual or manufacturer's website for any firmware updates that may address the issue.
If none of these steps work, it may be necessary to send the device in for repairs or contact Leica customer support for further assistance.
2/15/2023 6:01:56 AM • Leica Measuring... • Answered on Feb 15, 2023
Leica Disto A6 Laser Distance Meter Logo
Popular Tags
13 questions posted
Top Leica Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Leica Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Leica Measuring Tools & Sensors
Most Popular Question
getting error code 279 disto classic 5a
  • Measuring Tools & Sensors
