20 Most Recent
Lufkin & Hi Viz Tape Rule Questions & Answers
I pulled my Lufkin luorolok tape out the whole way
You need to take the screws out of the side but you may have broken the spring recoil mechinasum you can get a new tape but if the recoil is damaged its not worth fixing it would coast you more then buying a new one
Repair lufkin measure tape
Asking Lufkin is your best option as they might repair or replace for free or low cost.
The Official Site of Lufkin Brand Measuring Products
There are videos out there that will show how to take tape measures apart. However it can be tricky and if you are not careful the whole thing can become a mess to deal with. Most companies will not offer repair or replacement if you have tried to fix it yourself.
Measuring tape won't retract or advance
If it has gotten wet, muddy, or sand and grit in it you can spray WD40 in it and slowly move it in and out cleaning it as you go. do not pull it out to far ( no more than 6 inches past 49 1/2 feet. If ytou pull out a tape measure to far it will uncoil the spring and you will either need a replacement refill or just get rid of it and ask Santa for a new one. I have used broken tape blades for "measuring sticks". Simply cut them into 1 or 2 foot sections for hard to reach areas.....Joe
HOW TO CALABRATE LASER LEVEL
www.cooperhandtools.com.au/PDFs/%20Users%20Guide.pdf
used one before a few years ago for work. Found a pdf manual online but as we also had issues with calibrating we had to send back to lufkin for calibration 4 times within 12 months. We never treated it badly just had issues. Atleast it was under warr We as a company changed over to hilti. Not to give them the thumbs up but they lease tools. Anything went wrong they just replaced or repaired anything on the spot. Was more economical for a mid size co using alot of cordless and measuring equipment.
cheers. Hope it helps
How do you fix a broken tape and what size
pick up and throw out. purchase new one. If the tape head or foot. (End grabby bit) has broken or moved to far the tape will not read accurate. So if youre using a tape that has to be calibrated or has to be accurate its useless. hope it helps.
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
