20 Most Recent
DeLonghi DC300 Coffee Maker Questions & Answers
Delonghi Ecam 23.450S heating up please wait
'heating up please wait...' and that's it, suggests a fault with either a sensor or a control board... and in today's market, who could ever guess which?
I'm sorry this is far more philosophical than technical. I really hate to say this. Still, if any half-way modern appliance has given you 15 years' service, what more would you have expected?
Traditionally, you would have taken any faulty gizmo to a local repair expert, who would have fixed it for a charge greatly less than any replacement cost.
Today, it's almost inconceivable that the cost of even diagnosing, let alone fixing any fault would be comparable to the cost of replacing (whatever) with a new one.
The error code close door does not go off even if the service door was closed on DeLonghi Magnifica coffee machine
According to the De'Longhi UK website, the error message "Close Door" could be caused by two issues :
The brewing unit is not installed properly in the unit. You can try turning the unit off, remove and reinstall the brew unit, and then turn the unit back on to see if it reset itself.
The latch on the service door has coffee build up and is restricted from moving freely. Please clean the latch area and make sure the door closes.
If neither of these solutions work, you may need to contact DeLonghi support for further assistance.
We have a De Longhi coffee grinder KG100. The
First you pry the timer knob off and remove hopper, under the machine there a 4 tabs, using a small screwdriver pry those until the casing slides off.
Unscrew the nut holding the timer and take out timer, unplug the terminals, replace or try and repair.
Warning there a cogs and springs in there, i was unsuccessful.
Esam6700 hot water spout and milk frother not working:
Based on the information provided, it is possible that there is an issue with the machine's internal circuitry or wiring. It could also be a problem with the control board or the sensors that detect the presence of the milk jug or hot water spout.
One possible solution is to try resetting the machine to its default settings. To do this, turn off the machine and unplug it from the power source. Wait for a few minutes before plugging it back in and turning it on again. This may help reset any internal settings that could be causing the issue.
If resetting the machine does not work, it may be necessary to have it serviced by a professional technician. They can diagnose and repair any underlying issues with the machine's components.
It is also worth noting that regular maintenance and cleaning of the milk frother and hot water spout can help prevent issues from occurring in the first place. Be sure to follow the manufacturer's instructions for cleaning and descaling these parts of the machine.
Overall, if the issue persists, it is recommended to contact Delonghi customer support or a certified technician for further assistance.
