20 Most Recent DeLonghi CC 80 Coffee Maker Questions & Answers
The Owner' s Instructions for your CC80 can be found here:
http://dl.owneriq.net/3/334f817e-6ca6-4752-a5bf-540d618a7178.pdf
You may want to print a copy and save; DeLonghi sells copies for $4.99.
Refer to pages 8 and 9 for cleaning and descaling instructions.
DeLonghi CC 80... | Answered on Jan 30, 2011
I have the same problem. I think it's a factory defect. The descale button doesn't work, and it's never been descaled. I just leave vinegar in the machine overnight and run water to rinse it the next day. Vinegar is just dilute acetic acid. Citric acid works better than vinegar, but it's harder to find. It doesn't have the smell that vinegar does.
DeLonghi Coffee... | Answered on Jun 16, 2019
you probably have a problem with the flowmeter (one circular white, one hose from the tank enters the pump). You must remove the back cover of the machine and see them at the bottom left.
allow it to be opened by spraying and cleaning it.
Good luck
DeLonghi Coffee... | Answered on Jun 15, 2019
Not clear if loss of steam to milk dispenser or milk dispenser itself clogged.
Try descaling again. Try running the vinegar through tbe machine about 1/2. Then stop tbe machine and allow additional time for the vinegar to work.
Also run a clean cycle using vinegar.
Also try disassembling the milk dispenser and clean manually.
DeLonghi Coffee... | Answered on Jun 05, 2019
to me the pipe is blocked there is a tool to use to clean this pipe out, hard deposits in the water can block the steam pipe and the tool is a thin bendy wire that you put up the pipe to clean the pipe line out. i would think they sell this pipe in most out lets for coffee makers. check for coffee steam pipe cleaner.
DeLonghi Coffee... | Answered on May 29, 2019
DeLonghi CC 80 Coffee Maker Logo
Popular Tags
4 questions posted
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
MikePurcell
Level 1 Expert
Marvin
Marvin
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
DeLonghi Coffee Makers & Espresso...
  • DeLonghi Coffee Makers & Espresso...
Most Popular Question
anyone manual fro
  • Coffee Makers & Espresso Machines
