20 Most Recent
Horizon AFG 5.0 AT Treadmill Questions & Answers
Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
JUST BOUGHT A USED HORIZON FITNESS TREADMILL THEY
Hi, you can get the manual of the horizon fitness treadmill. First you did not write out the model of the fitness treadmill, but i will give you a link for you to get the manual. Just go to this site (www.manual.com), enter the site you will see the search column. Type the name and the model of the fitness treadmill you have and it will show you the manual of the fitness treadmill. Have a nice day.
How to fold my afg 5.0 treadmill for storagae
Dear Sir:
Hello , i hope everythign is o.k
Please do the following:
FOLDING
Firmly grasp the back end of the treadmill. Carefully lift the end of the treadmill deck to the upright position until the foot
lock latch engages and securely locks the deck into position. Make sure the deck is securely latched before letting go. To
unfold, firmly grasp the back end of the treadmill. Gently press down on the foot lock latch with your foot until the lock
latch disengages. Carefully lower the deck to the ground. NOTE: on some models the foot lock latch might be on the right
hand side. NOTE: when folding the Horizon Fitness Treadmill the console assembly will tilt away from you, but will return
when fully folded in the upright position. Please allow two additional feet from wall when folding.
Thank you in advance, sincerely. Blessing.
If you need additional help, please contact me.
e.cuadra
Managua, Nicaragua C.A.
How to fold up
hi,
Pull the walking deck to upward 90 degree and push it towards to the contol panel .
I turn the treadmill on
Your safety key is the magnet switch with the cord attached to it on the front of your computer. If the computer says the key is off then try repositioning the safety key magnet. If it still doesnt work you may have a loose wire behind the key section.
There is a clicking sound
hi,
check the motor, may be its bearing have some problem. if u can see the motor then put some oil on its bearing. take care open treadmill only after removing the power.
ok
Does the Horizon 7.0 AT have a fuse on the MCB?
Hey Sharon,Hope so you're doing fine, there is typically no separate fuse on the MCB (Main Circuit Board). The MCB itself is responsible for controlling the incline and belt functions of the treadmill. If the top board turns on but the incline and belt do not run, and the MCB is flashing a safety key error message, it suggests that the safety key might not be properly engaged or there could be an issue with the safety key sensor.To troubleshoot the problem, make sure the safety key is securely inserted into its slot and properly aligned. Check for any visible damage or debris that might be obstructing the safety key sensor. If the issue persists, it is recommended to consult the treadmill's user manual or contact Horizon customer support for further assistance. They can provide specific troubleshooting steps or guide you through any potential repairs or replacements that may be necessary.Hope so this will work for you!Regards,Bryce JuneCEO & Founder of https://bbcorhitter.com/
