20 Most Recent Proform PFTL79807 - 850 W/ Gamefit Elliptical Questions & Answers
Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
6/25/2020 6:07:16 PM • Proform... • Answered on Jun 25, 2020
Problem with Spirit elliptical, makes clicking
If you wish to get some details; check the site linked here. Pull up older posts. Search for spirit elliptical articles. http://electro-medical.blogspot.com/
5/31/2016 5:59:59 PM • Proform... • Answered on May 31, 2016
0answers
Proform 450 le
Be the first to answer 6/6/2014 6:53:33 AM • Proform... • Posted on Jun 06, 2014Be the first to answer
0answers
Proform 390e motor
Be the first to answer 5/11/2014 4:41:43 AM • Proform... • Posted on May 11, 2014Be the first to answer
2answers
I have an older proform elliptical and the battery cover cracked.
Go to FitnessRepairParts com and type in your exact model number in the search box at the top to view the parts list for that model. You may be able to find a cover there. Or you can contact support if you can't find your exact model number, they are very helpful
2/14/2014 2:07:42 PM • Proform... • Answered on Feb 14, 2014
2answers
Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
1/25/2014 5:49:45 PM • Proform... • Answered on Jan 25, 2014
What is the voltage of charger or power pack?
The model number you posted is for a treadmill, not an elliptical machine. If you can locate the specific elliptical model # located on the frame decal (where the serial# is located) we can help you find the answer
12/3/2013 10:14:02 PM • Proform... • Answered on Dec 03, 2013
Proform 480 LE installed new
If you need a parts list for the PFTL79807, see here.
11/20/2013 3:12:27 PM • Proform... • Answered on Nov 20, 2013
I have proform smart stride. When you turn it on,
follow this steps and fix it. God bless you · 1 Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance. · 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced. · 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine. · 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break. · 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine
10/18/2013 12:01:25 PM • Proform... • Answered on Oct 18, 2013
Proform 950 Adjustable Knob
go www.fitness.manualsonline. com + www.doctortreadmill.comand get it GOD BLESS YOU
7/27/2013 12:58:54 PM • Proform... • Answered on Jul 27, 2013
My 390 E is locked up and I can't move the pedals. I checked the belt, it's still on and it's tight.
follow this steps and fix it. God bless you Electronics Problem You control the tension of the pedals using the buttons on the console. When you assemble the A.C.T. elliptical, you have to thread a group of wires from the console through the upright down to the electronics board. These wires communicate the resistance settings to the electronics board. If the wires twist, disconnect or break, the resistance will not work. You will need to reconnect or replace the wires. Read more: http://www.livestrong.com/article/406522-tension-problems-with-the-nordictrack-a-c-t-elliptical/#ixzz2Z4kLeLBm
7/15/2013 2:02:21 AM • Proform... • Answered on Jul 15, 2013
Display on Proform 490 LE elliptical shows FF -- How do I fix it?
1) PLEASE replace batteries by new ones.2) clean the batteries contacts with special spray contacts cleaner3) retight the spring contacts batteries with a pliers for better contacts very important!4) adjust the reed switch see the diagram attached.God bless yu7_9_2012_12_30_31_pm.gif
7/9/2012 12:30:47 PM • Proform... • Answered on Jul 09, 2012
My proform 2605 elliptical the right foot pedal is
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
11/30/2011 12:04:33 PM • Proform... • Answered on Nov 30, 2011
I am getting very frustrated, i want a owners
Go to website from Proform: www. proform. com then go customer service , then go to part& manual give you model, serial number and download free you user or owner manual and Ready!SINCERELY.e.cuadramanagua, nicaragua. c.a.
11/28/2011 6:31:48 PM • Proform... • Answered on Nov 28, 2011
My Pro-Form 330 elliptical has a resistance
11/28/2011 5:38:37 PM • Proform... • Answered on Nov 28, 2011
Belt came off and need to put back on
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside. 2
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt. 3
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.SINCERELY. GOOD LUCK.ERNESTO CUADRAMANAGUA,NICARAGUA
11/26/2011 12:42:25 PM • Proform... • Answered on Nov 26, 2011
Proform PFTL79807 - 850 W/ Gamefit Elliptical Logo
59 questions posted
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
older proform elliptical battery cover
  • Exercise & Fitness
