hi,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck.
Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video.
ok
Hi there!
L5 sometimes may refer to LS(Low Speed). There might be a problem with your motor sensor. It is best to call the place where you purchased this device for possible replacement if a reboot will not suffice.
Talk to good astrologer online. The most authentic service of Indian astrology. The easy and cost effective remedies. Energized gemstones remedies available free of cost.
You can reach me on this link DsK Astrology
You might be able to get it if you search for Sears online. they closed most stores but have a web site. If they do not help you, you might be able to get the board fixed by a competent electronic repair person.
That's not a Sears part number. Look for a plate on the motor housing. There will be three number, a dot, and several more numbers.
Then go to https://www.searspartsdirect.com/ , enter your model number and open the parts breakdown. The manual is usually near the end of the parts list, often there's no related part number associated.
