20 Most Recent
Matrix T3Xi Treadmill Questions & Answers
Hi, i have an Error
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Matrix MX-3 error code 1
see the diagram attached for the speed sensor. test for open or faulty. clean it, and tight for plug or connector.2) Test the input voltage motor, if there are the motor need repair3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.God bless you
Display is not working
tight the ribbon cable from keypads , clean it +tight the wires connector from display board vs lower board and clean it.2) adjust the reed switch, clean it and tight the wires connector too, see the diagramGod bless you
My Matrix T3X treadmill display doesn't work
tight the ribbon cable keypad, clean it +tight the wires connector from display board vs lower board and clean it.2) adjust the reed switch, clean it and tight the wires connector.see the diagram.God bless you
ERROR CODE E 7
Have you tried to recalibrate the unit? Walking belt sticky at all? Smell anything? Does this use a red dc motor? If so, check for a burnt "choke" (looks like a small transformer near the controller bd). Elevation function at all? Can you get the walking belt to start?
Treadmill only works for 15 secs
1) If the the belt is moving during that time then stop I would suspect that speed sensor maybe defective.
Replace the sensor
2) Now if their is no belt movement then either Motor Control board or Drive Motor is defective.
Do Motor Test
I would check the drive motor first to eliminate an expensive component, unplug unit then remove motor shroud then unplug the connectors leading to the motor itself. If you have wire leads and a 18v drill battery connect the leads into motor then attach the other end to you battery and if the motor will rotate ( approx. 1mph) if that is accomplished then the only other component to be replaced would be the Motor Control Board. Call Matrix for parts @ 1-866-693-4863 option 3
