20 Most Recent RTO Sole F80 Treadmill Questions & Answers
2answers
Error code of ls1 on sole f80 treadmill
John what are you talking about. All that's gonna do is give a LS error if you disconnect the motor.
10/20/2022 4:02:14 PM • RTO Sole F80... • Answered on Oct 20, 2022
Why does display console freeze after turning on?
The display screen has stopped working and needs to be replaced.
3/27/2021 6:59:57 AM • RTO Sole F80... • Answered on Mar 27, 2021
2answers
Sole F-85 treadmill E-5 error
If you wiah to get some details about treadmill error codes and solutions then check the following link http://electro-medical.blogspot.com/
6/30/2020 6:11:47 PM • RTO Sole F80... • Answered on Jun 30, 2020
2answers
I have a sole f80
hai , check communication cable, speed sensor
2/23/2020 6:25:16 PM • RTO Sole F80... • Answered on Feb 23, 2020
2answers
My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.2) You must align the deck belt see the diagram3) Lube the rollers bearing very well very important toosee the video: God bless you5_15_2012_3_26_28_pm.gif5_15_2012_3_26_41_pm.gif
5/17/2017 3:49:42 PM • RTO Sole F80... • Answered on May 17, 2017
E2 code on f80
CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz 1)faulty speed sensor or 2) the speed sensor is not plugged in properly 3) Need to adjust again face to face against motor magnet . 4)faulty motor Test without load measure 115vac. 5) control board or lower board test if 115 vac are coming to the board 6) See the transformer measure primary voltage and secondary 7) Test the power supply for +5Vdc 8) See if there are component burn. 9) Lubricate the Deck belt 10) Adjust the tension for Deck belt by 2-3" for lift .The error codes will differ between makes and models but could be e1-e2See the block diagram for diagnostic and take your resultant.Sincerely. Merry Christmas.ernesto cuadramanagua, nicaragua12_19_2011_6_20_58_pm.gif
3/29/2016 2:17:01 AM • RTO Sole F80... • Answered on Mar 29, 2016
0answers
2answers
Motor is not responsive and it read LOW SPEED message and time L51
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify. Make sure the console cable is not pinched or damaged in any way. Turn the power off, unplug the power cable and wait 60 seconds. Remove the motor cover. Wait until all red LED lights have gone off on the motor control board before proceeding. Next, verify that none of the wires connected to the lower board are loose or disconnected.
1/19/2016 8:09:43 PM • RTO Sole F80... • Answered on Jan 19, 2016
manual
When I turn on and select start, it powers down as it trips the house circuit. Why is this happening, it has never before?
Could be that there is a short in your wall outlet, you can try switching the treadmills power cord to a different outlet. You always want to make sure that your treadmill is on a dedicated circuit. You also might want to try and just reset the power switch, leaving it off for 5 minutes and switching it back. It could also be that one of the electric components on the main board, for example like a capacitor is damaged which in turn is causing the unit to draw "too much" voltage into the machine. If switching outlets does not do the trick, you can remove the main shroud and inspect that main board, check any wires for crimping and or any components that look damaged. If not any, with the shroud off you can turn the machine on. Just check to see if the main control boards LED's come on. You will most likely get LED's since you said it turns on, then off when you hit start. If you find you need any further assistance, we would be happy to help you :) by chat at www.sportsmith.net or by phone at 888-713-2880 We look forward to hearing from you!
8/18/2015 6:02:03 PM • RTO Sole F80... • Answered on Aug 18, 2015
How do you "run the software calibration"?
  1. Turn unit on
  2. Pull out the safety key
  3. While holding down the 'start' and 'speed increase' button insert the safety key. Unis should now say calibration.
  4. Press enter on all options until screen does not change when you press.
  5. Press 'Start' (Unit will run auto calibration). If passed, the unit will reset itself. If fail it will say 'fail'.
  6. If you do not see 'fail' power off, then on again once done.
  7. You're good to go. (If unit says 'fail' contact service)
Techmotion Corp does service and repair in many north-east states. Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
6/24/2015 2:10:57 PM • RTO Sole F80... • Answered on Jun 24, 2015
Low speed fault
With belt movement check speed sensor. Without belt movement check MCB. If you neglected unit it could be belt and deck if its shutting down during a workout. I have also see a lot of on/ off switches getting old and causing LS errors due to low voltage to MCB
8/16/2014 3:24:54 PM • RTO Sole F80... • Answered on Aug 16, 2014
3answers
New F80 treadmill. Belt doesn't move after hitting
hi, check the 12pin communication cable
8/16/2014 1:21:47 PM • RTO Sole F80... • Answered on Aug 16, 2014
2answers
When i step with my right foot the left frnt wheel lifts off ground, how do i fix this?
My first thought is to adjust the leveler foot on the back right of the deck. If the lock nut is loose the foot may need to be screwed out so the deck is solid on all four points.
7/7/2014 12:19:43 PM • RTO Sole F80... • Answered on Jul 07, 2014
0answers
RTO Sole F80 Treadmill Logo
104 questions posted
Top RTO Exercise & Fitness Experts
Jennifer Rock
Jennifer Rock
Aron
Sportsmith LLC
Sportsmith LLC
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • RTO Exercise & Fitness
Most Popular Question
replace running belt
  • Exercise & Fitness
