20 Most Recent
Electrolux EOC6630 Pyrolytic Electric Single Oven Questions & Answers
Fan will not turn off
Hi
you have a faulty cut out stat. if you unplug oven , remove from housing and take lid off
near the cooling fan on top cable tied in the wireing is the cut out . it has 4 wires going in it 2 blue 2white just replace it and will be back to normal hope this helps you
regards dan
Need help with re-installation
ovens don't usually come with a cord. check handbook for cable size and you should find a connection block behind a plate at back. just connect to outlet making sure you get connections correct - they are usually identified on terminal block
Electrolux Oven 5d or Sd error code/demo mode
- Turn off the oven.
- Press and hold the "Bake" and "Broil" buttons.
- Turn the oven on by pressing the "On/Off" button.
- Continue holding the "Bake" and "Broil" buttons until the display shows "PF" or "8.88."
- Release both buttons.
If these steps don't work, refer to the user manual or contact Electrolux customer support for further assistance.
