20 Most Recent
Canon Powershot SX10IS 10MP Digital Camera with 20x Wide Angle Optical Image Stabilized Zoom Questions & Answers
Total power failure after replacing battery door on Canonsx10is
Battery doors are notorius for being difficult to replace unless you have circuitry skills, at least for the ones with more than just a detent switch. Many have wires connected internal to the hinge. You may have inadvertantly severed the door wiring. Not having access to a technical manual, you would never know without calling Canon.
How do I attach the wrist strap to the Canon PowerShot D30 camera
The wrist strap has a thin loop on one end. Thread this thin section (like threading a needle) through the strap hole. (It's on the left side of the camera. There are two openings with a bar over the top of the center of them at the bottom corner of the camera body.) Start threading from the middle of the body of the camera and push the strap towards the bottom of the unit. You may need to twist the loop to narrow it and keep it tight. Once you have this narrow loop through the camera, open up the loop and slide the thick material through the center of this thin loop. Pull the wrist strap until the thin loop tightens around the bar.
This is shown on page 12 of the D30 manual. The manual is available from Canon support on the Powershot page:
http://gdlp01.c-wss.com/gds/5/0300013985/02/psd30-cu2-en.pdf. The direct link to the manual is
http://gdlp01.c-wss.com/gds/5/0300013985/02/psd30-cu2-en.pdf .
I hope this helps.
(Many lanyard straps for electronic gear work the same way. Threading the narrow section under that bar does require decent near point vision. People who are far-sighted may need to wear bifocals or ask someone younger to assist.)
LOST THE VOLUME ON VIDEO, HOW TO FIX?
Do you mean when playing video back on the camera? If so, when the video is playing, press on the top of the wheel, the part with the triangle pointing upwards (up-arrow). You should see the small volume level indicator get an increasing number of bars and the volume will increase.
