20 Most Recent
1600XP Security/Remote Start System Questions & Answers
Remote draining car battery(can't findoff switch)
First disconnect the battery. Switch everything off you can find. Reconnect the battery and one by one switch on each individual item until you find the one that you can't switch off. Radios and clocks are the two main culprits. Alarms would be third on my list.
12/1/2022 11:56:43 PM •
1600XP...
Answered
on Dec 01, 2022
Hey all! I have absolutely no fuel pressure
why don't u try online websites..
some websites deal in it real time.. along with solutions to problems how to repair fix service nd all let me know if u need help I know plenty
1/28/2019 10:18:39 AM •
1600XP...
Answered
on Jan 28, 2019
When I press the button open and close doors its
If the parking lights are flashing when you attempt to start the vehicle, it is an visual notification to you as to the reason WHY it doesn't start.
Six flashes of the parking lights is (-) or (+) shutdown and seven flashes is neutral safety shutdown. These are the most common reasons for remote starter malfunction. The (-) shutdown relates to the hood pin switch. A malfunction in this area occurs when the hood pin switch fails to make contact with the hood when closed. Adjusting the pin or the bracket it may be attached to will solve the problem. The (+) shutdown relates to brake wire. Unless you have your foot on the brake while attempting to remote start, the issue could be with the brake switch or the wire making contact with 12 volts during remote start operation. The neutral safety shutdown relates to either the toggle switch or, if this is a new installation, the thin black with white stripe wire NOT being connected to ground. If your remote starter has worked before and, is not working now, the issue will be with the toggle switch. The toggle switch will be located (usually) under the dash near the left kick panel. The kick panel is where your left would rest when driving.
3/24/2011 3:59:10 AM •
1600XP...
Answered
on Mar 24, 2011
The vehicle starts but runs only for about 1
you need to re-program your factory alarm bypass module. if you haven't used on then you will need to find out which one you need for the vehicle and install it. Check the Viper/DEI Website for details.
If your module is in, check the Can Hi and Low connections to be sure they are to the correct wires.
1/6/2011 3:59:28 PM •
1600XP...
Answered
on Jan 06, 2011
How to reset python remote starter
hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this .. im a frequent buyer there since Im a mechanic so take help from there
Snakes that twist around branches
If you are in the south part of the US, especially if it is around a pecan tree, would suspect it to be a copperhead. At night they like to climb trees and eat insects that also hang out around trees. They blend in very well and starting at dusk, you might want to avoid the base of trees. A rattlesnake also will climb a tree especially if they just ate a rat or something. Have had them drop down on me while walking under a tree.
Chamberlain hbw1573 work with Python 2?
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
How to reset python car starter remote
you can get guide from many sites.. i know few
