20 Most Recent
5103L Security/Remote Start System Questions & Answers
What do I need to connect on the 5103L and what can I leave unconnected?
I would suggest you connect alarm , the door trigger ( usually green) - to the dome light wire that can be found inside the door. If there is no pin in the door it's inside the door panel by the latch and shows - when door or latch is open. It is also possible to connect to the dome wire in the ceiling but dome light delays will cause a problem or if there is no light. You need to connect the starter wire possibly blue red on this car, two ignition wires on the car colors possibly red and red yellow for the second ignition wire. Brake light wire possibly white black above switch pedal. Battery or constant possibly black yellow at ignition switch. Parking brake is usually required. On this car you will need to add a actuator in the driver side door to unlock and lock the car. Diagram is to use two relays, can be found on websites. Adding actuators to a door. You will need to disarm the alarm with the alarm disarm wire on the alarm the disarm wire on the car is possibly white green it is negative in the driver kick panel.
5/8/2014 1:01:19 AM •
5103L...
Answered
on May 08, 2014
Neutral remote
Check under the dash on the car. All remote start systems have a shut off toggle switch to turn the system off. If you had your car in for service then they may have flipped the switch. It is either under the dash somewhere or sometimes it is put under the hood where it can be seen by the mechanic.
1/31/2014 2:22:42 AM •
5103L...
Answered
on Jan 31, 2014
I am trying to remote start my car and it wont
The secondary chirp alerts you to an open trigger, probably the hood pin switch since the car is not remote starting. Check under the hood for a broken or bent out of place hood pin switch. Make the adjustment so the pin makes contact with the hood when the hood is closed.
2/5/2011 3:36:20 AM •
5103L...
Answered
on Feb 05, 2011
How can put my Avital 7345L remote starter on vibrate instead of chirping?
To put your Avital 7345L remote starter on vibrate instead of chirping, you will need to follow these steps:
- Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will put the remote starter into valet mode.
- Press and hold the "Lock" button on the remote starter until the parking lights flash twice. This will turn off the chirping feature.
- Press and hold the "Unlock" button on the remote starter until the parking lights flash twice. This will turn on the vibrate feature.
- Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will exit valet mode and save your settings.
- Test the remote starter to make sure that it is vibrating instead of chirping.
Note: If you have difficulty following these steps or if you have any other issues with your Avital 7345L remote starter, it is recommended that you consult the user manual or contact the manufacturer for assistance.
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
