20 Most Recent
Gateway NE56R Dual Core 2.10GHz 4GB 320GB 15.6 WIFI HDMI Windows 7 w/ 8 Upgrade Questions & Answers
Gateway NE56R
1. Flip your unit over to its back and remove the battery.
2. Remove the screws on the large cover and remove the cover.
3. You will find the memory and hard drive under that cover.
P.S you should use a static guard to remove any of those parts.
Hope this helps
Hi, am ganesh functions keys
If those are the only keys on the key board that are not responding, I would try to
1. boot in safe mode and check response. If you have other keys on the laptop that are not working,
2. I would boot operating system from a flash drive and check
and if both still are not working for you
3.try an external key board
Last replace the key board
Hope this helps
Display colors on monitor
In windows7 you can go to your device manager and remove and re-install your video drivers.
Also check for flags under that device.
You can get updated drivers for your unit at Gateway
VGA driver
The best way to fix this issue is to download the latest driver from you pc`s manufacturer`s website and then re install it hopefully this shall solve your problem.
My mouse pad wont scroll or move through apps like it used to
Hello, There are two things that you can do.1. System Restore2. Update the driverTo do the system restore, do the following:Click on Start > Programs > Accessories > System tools > System RestoreSelect a restoration point.Make sure that it's before the time when the problem occurred. Launch it. If it doesn't work, try a different restoration point.To update the driver, you can use RadarSync. It will scan and install the updates to your computer. All drivers will be covered so you're sure that all possible problems (driver related) will be fixed.I hope this helps!David
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
