20 Most Recent Polar RS200sd Running Computer Heart Rate Monitor-Red Questions & Answers
Polar RS200 does not sync using weblink. What should mic settings be on Lenovo T420?
Dear Jan, the link of master reset a RS200 is no longer working...Help!! do you know the steps?
9/17/2016 8:16:10 AM • Polar RS200sd ... • Answered on Sep 17, 2016
Minutes go to 19 then go back to 0
go to www.polar.fi and download the instruction manual, for to fix the monitor.sincerely. God bless you
4/26/2012 12:31:50 PM • Polar RS200sd ... • Answered on Apr 26, 2012
Setting the time
Settings for time are under settings - watch.
To get to watch you must first get to settings: Push either of the right side buttons untill you see settings appear. Then push the RED button (that is your chooser, the others are scrolls).
Now scroll though till you find watch, then choose with the red button and continue on through the prompts.
If you need a manual you can download one for your watch from my link in my tips and tricks page.
12/26/2010 11:01:21 PM • Polar RS200sd ... • Answered on Dec 26, 2010
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see www.polar.fi under support in forums) link: http://forum.polar.fi/showthread.php?t=14065 - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
6/13/2010 8:54:50 PM • Polar RS200sd ... • Answered on Jun 13, 2010
How do I change the time?
Hi. Isn't it annoying!
Top right button to File
Scoll to Settings (Press OK)
Scroll down to (!) Watch (Press OK)
Scroll down to Time 1
6/11/2009 5:59:26 AM • Polar RS200sd ... • Answered on Jun 11, 2009
JK Exer Polar 5090 treadmill. I have Error Code E1.
Question edited for clarity and its proper name. E1 is a speed sensor error. Sometimes it just needs cleaning/
E1 Error Codes
The Treadmill Engineer http://www.treadmill-engineer.com > 2016/02 > e1-err... Feb 29, 2016 - If the E1 error occurs after the belt starts to move for several seconds, the error code means that the system is not picking up the speed of ... Missing: 5090 ‎' Show results with: 5090
jkexer e1 Questions & Answers (with Pictures)
Fixya https://www.fixya.com > Forum > Tags > jkexer e1 ...jkexer polar 5090 treadmill and its coming up E1 any ideas please 1) You must adjut the speed sensor, clean it, tight the connector very well.see the ... images ..
2/20/2024 8:30:24 PM • Polar Exercise &... • Answered on Feb 20, 2024
I need the manual for polar heart monitor model f43**********
The item Model F43 is obsolete and no longer supported. However, here is a general Manual you might find useful. See link below https://support.polar.com/e_manuals/Move/Polar_Move_user_manual_English/ch05.html
3/2/2019 7:41:08 PM • Polar Exercise &... • Answered on Mar 02, 2019
0answers
Hi I have just bought a Sole F85 (2016/2017) treadmill. I was advised it the F85 would work with my Polar H7 and H10 heart rate monitor as these synch with my iPhone and V800 Polar devices H7and H10 are both open source 5kz analogue signal however the F85 does not pick up the signal from the Polar HRM why is this as I was told F85 operates with and can receive a 5kz signal. Polar are leaders in heart rate monitors and all the gym equipment I have used for the past 15 years has been compatible with the Polar Product I am starting to use the Sola Fitnesss application but the F85 Treadmill I have just purchased does not appear in the list for connections there is a blank line which when selected sometimes connect to the F85 via Bluetooth. There appears to be a bug in the software. Also there is connectivity to other apps Fitbit, HealthKit, Mapmyfitness but there is no connectivity to Polar Polar are the leaders in heart rate technology and one of the largest producers of HRM products so when can the Sole Fitness application be developed to include an interface / connectivity with the Polar Flow and Polar Beat applications. Also can the Sole Fitness application be developed so is can use via Bluetooth a Polar heart rate monitor (chest strap)? If Sole Fitness can pick up HRM data from Polars H7 or H10 via Bluetooth then it could be an interface to the F85 Treadmill, is this possible as part of the Some Fitness application development. Also I have noticed that the pulse readout is totally inaccurate as my V800 says 130 bpm and the display on the F85 says 78 Any guidance would be much appreciated
Be the first to answer 11/4/2017 6:40:06 PM • Polar Exercise &... • Posted on Nov 04, 2017Be the first to answer
Polar RS200sd   Running Computer Heart Rate Monitor-Red Logo
10 questions posted
Top Polar Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Polar Exercise & Fitness
Most Popular Question
change time
  • Exercise & Fitness
