20 Most Recent
Canon imageCLASS MF4890dw Wireless Multifunction Laser Printer, Copy/Fax/Pri Questions & Answers
Why won't labels feed?
Labels are a tough feed for any printer because the surface tends to be slippery. Yes you should replace your pickup roller or at least clean it with a damp cloth so that the surface is grippy and not coated with paper dust.
I want to contact to canon xerox service centre kolkata
http://www.xerox.com/about-xerox/contact-us/enin.html
Contact Us - Xerox
Find a local Office Products dealer in your area: Kolkotta Office Xerox India Limited 37, Shakespeare Sarani, 1st Floor, Kolkata - 700 071. Sales: 033 - 44004875 ...
- Copiers like the Xerox personal copiers offer functionality that takes into consideration ... 8/1, Lalbazar Street, Room No.1 D ,1st Floor, Kolkata - 700 001, India.
http://www.copier.in/photocopiers/personal-copiers.html
Canon ir 1024 iF shows E808 code error. How can it be fixed?
1) The error E808 occurs when one of the connectors in the fixing assembly is not properly plugged in when the unit is on.
2) This might have occurred while replacing the fixing assembly or performing a troubleshooting attempt on the machine.
3) You can find the connector above the fixing assembly at the right corner, behind the cover on the machine's side.
4) To clear the E808 error, unplug the machine from the power supply for at least 10 minutes. The error will appear again if the thermistors are in bad condition.
5)The fixing film assembly should be replaced in such case.
For more printer related assistance get in touch with our experts by just giving a call @ 1-866-293-9220.
