20 Most Recent
Electrolux Central Vacuum Questions & Answers
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
How do you rewire a relay
The relay contacts are wired in series with the motor, circuit breaker and switch. The relay coil is wired in series with the transformer secondary circuit, the control wires to the valves in the wall. Also the on switch is wired in parallel with the control wires.
You did not ask about the transformer but the primary windings are wired to be always on. If you need a picture I can draw you one.
Burning smell
Something may be keeping the brush roll from spinning freely which may have caused the belt to break.
